So Cal 4Runner BS Thread
might be a long shot, but do any of you have removed emblems from a 4th gen laying around? specifically looking for the "4" from the 4RUNNER badge on the back door. will trade for beer.
[MENTION=142678]grave[/MENTION] I missed this post last week. I have a '4' from the '4WD' I removed from the door. It looks like a match if you still need one.
hey guys, so i went to that 4wheelparts event in gorman yesterday. did a trail run with them through the wash. not sure what the trail is called, but it was the "hard" trail run. got through it ok (needed a pull to get up one of the hills though, an e-locker woulda done the trick).
but more importantly, i won a $50 gift card to 4wheelparts :D
so, looking to buy a portable air compressor now and i'm not really sure what to get.
88P Portable Compressor Kit, $65.99:
12-Volt
Duty cycle = 45% @ 100 PSI
Max working pressure = 120 PSI
Dimensions = 9.8"L x 3.1"W x 5.6"H
Inflates 33" tires
VIAIR - 88P Portable Compressor Kit | 4WheelParts.com
Viair 90P Portable Compressor Kit, $79.99:
12-volt
Duty Cycle: 15% @ 100 PSI
Max Working Pressure: 120 PSI
Max Amp Draw: 22 Amps
Dimensions: 6.77" L x 6.18" W x 6.13" H
Features
Vibration Isolators
120 PSI Pressure Guage
Clip-On Tire Chuck w/ built-in bleeder valve
Dual Battery Clamps
12 ft power cord
3 ft. hose
VIAIR - 90P Portable Compressor Kit | 4WheelParts.com
These two seem like the right price and are portable. Not sure if I should spend a little extra and get the more expensive one. Thoughts?
I have the 88P, works well for me. You're more than welcome to try it out to see. Maybe someone here has a 90P you can try out, too.
sweet. appreciate that man!
any idea on how long it takes for you to air up, esp compared to the others that run different portable air compressors? how long have you used the 88P?
Ok so after doing a little more looking around, I think I'm going with the 88P because it is more powerful.
88P: 120 PSI / 1.47 CFM, good for up to 33" tires
90P: 120 PSI / 1.21 CFM, good for up to 31" tires
CFM is pretty much the most important thing to look at, right? based on CFM, 88P is the way to go.
To get from 20psi to 45/50psi I think it took like 4 minutes per tire. Not sure exactly but I can check next time.
LOL. It's 4BYFOUR :rockon:
:reddance::reddance::reddance::reddance::reddance::reddance:
nice!
i was gonna ask about the blue/yellow plates because i thought those would be period-correct, but a quick google search shows that CA plates had gone white/blue in the 80s. i really thought blue/yellow was still being issued in the early 90s.
That's not exactly true, you want to look at the duty cycle also. I have a Viair 400 (similar to 88P) which I re purposed from my air suspension from my Audi. Both 88P and 90P compressors you're looking at are good up to 120 max psi meaning they can pump up to that amount, so either will work for all sized tires.
The duty cycle shows how long it can run before it needs to be shut down from overheating. The lower the % better, meaning the one with lower % can be run longer before it overheats. Generally the lower % pumps less air and will take longer for each tire to be filled. Think of the 88P as a sprint racer and the 90P as a marathon racer.
So both would be fine filling up 4 tires after airing down for a trail run but if you plan to let someone in the group borrow it to fill up theirs then I'd get the 90P as it can run longer without overheating.
I have the 88p and I air up from 18psi to 40 psi on 255/80/17 (skinny 33's) in about 4 mins per tire. For the price it's a decent compressor. I use an ammo can to store it since it doesn't come with a bag. They get super hot after use so an ammo can is better than a nylon bag anyways IMO. The only word of wisdom with the 88p is to check your psi manually with a decent air gauge as you near your desired psi. The one on the compressor isn't very accurate and I'm usually 2-3psi lower than what the built in gauge is reading. I bet most economy compressors are similar in that regard.
I haven't tried the 90p either, but I bought he 88p based off the tire size recommendations on Viair's website. My understanding about duty cycle is that the higher percentage means the more minutes per hour it can be run before needing to cool.
Anyone catch sight of a rainbow the last couple days? The rain has been a nice change from the norm.
Opps you're right I had it backwards from my first statement, the higher the duty cycle % the better. Basically the higher the duty % the longer you can run the compressor before it needs to cool down. My 400c compressor is also pretty hot after I fill all 4 of my tires from 20lbs to 35lbs.
Garage Sale!!
OK guys I want to post this here and have the socal member get dibs before I post it on for sale thread and craigslist. I'm selling a few item for 3rd and 4th gen 4runner. As a lot of you know me and the upgrades I've done with Lola and Lucy pearl, most of the suspension and gears are new and lightly used (not much mileage) I will post pix later but pics have been posted on different thread in this sections.
FOR SALE!
4th gen. May work 3rd gen. Bought this maybe in April or May 2016. Switch to Allpro 3.5 springs and fox 2.0 shocks.
1. 2014 FJ 4X4 rear springs $100 - bought new maybe around 2k miles on it. Mostly freeway and 2-3 offroad trips. SPRING, LEFT for 2014 Toyota FJ Cruiser|48231-35420 : Toyota Online Parts | toyotaonlineparts.com | Toyota Parts Online x 2
2. Bilstein 5100 $150: Bought new and same as fj springs around 2K miles. Mostly freeway and 2-3 ofroad trips. https://bilsteinlifts.com/shop/toyo...cks-for-toyota-fj-cruiser-and-toyota-4runner/
3. USA Standard Gear 4.56 ring/pinion and bearings $300: New and never installed. Decided not to because bought Lucy Pearl (3rd gen 4wd)
For Sale 3rd Gen: upgrading rear suspension to OME861 and LC Tokico shocks. These doesn't have much miles at all. Bought new in August 2016 and maybe have 800 miles on it. Not my daily driver so sits around. Mostly freeway miles and 2 offroad trips to big bear.
1. 3" Toytec rear progressive spring $150: ToyTec Rear 3" Medium Coils (96-02 4Runner)
2. Toytec Boss rear shocks $180: (2) TT-9602R - Toytec Rear BOSS Shocks - 96-02 4Runner
Prefer local pick up. Let me know Gents!
2001ATL
