So Cal 4Runner BS Thread
Garage Sale!!
OK guys I want to post this here and have the socal member get dibs before I post it on for sale thread and craigslist. I'm selling a few item for 3rd and 4th gen 4runner. As a lot of you know me and the upgrades I've done with Lola and Lucy pearl, most of the suspension and gears are new and lightly used (not much mileage) I will post pix later but pics have been posted on different thread in this sections.
FOR SALE!
4th gen. May work 3rd gen. Bought this maybe in April or May 2016. Switch to Allpro 3.5 springs and fox 2.0 shocks.
1. 2014 FJ 4X4 rear springs $100 - bought new maybe around 2k miles on it. Mostly freeway and 2-3 offroad trips. SPRING, LEFT for 2014 Toyota FJ Cruiser|48231-35420 : Toyota Online Parts | toyotaonlineparts.com | Toyota Parts Online x 2
2. Bilstein 5100 $150: Bought new and same as fj springs around 2K miles. Mostly freeway and 2-3 ofroad trips. https://bilsteinlifts.com/shop/toyo...cks-for-toyota-fj-cruiser-and-toyota-4runner/
3. USA Standard Gear 4.56 ring/pinion and bearings $300: New and never installed. Decided not to because bought Lucy Pearl (3rd gen 4wd)
For Sale 3rd Gen: upgrading rear suspension to OME861 and LC Tokico shocks. These doesn't have much miles at all. Bought new in August 2016 and maybe have 800 miles on it. Not my daily driver so sits around. Mostly freeway miles and 2 offroad trips to big bear.
1. 3" Toytec rear progressive spring $150: ToyTec Rear 3" Medium Coils (96-02 4Runner)
2. Toytec Boss rear shocks $180: (2) TT-9602R - Toytec Rear BOSS Shocks - 96-02 4Runner
Prefer local pick up. Let me know Gents!
I have the OEM 861s and LC Tokico shocks on my rear. Be warned you will have massive rake unless you get a heavy bumper with tire carrier.
Garage Sale!!
FOR SALE!
That all 4 4th gen 5100s or just rear? Been thinking about picking up some 5100s for the Tacoma. Not planning on lifting but my stock shocks have 105k miles on them.
Just rear but you're still saving if you pick this up and then buy fronts. The fronts are still on Lola!
I have the fronts sitting in the garage with a pair of 885s on them, haha. I'll have to think about it. Need to get the rear leaf spring recall done and see if I can get them to upgrade me to the 4 pack. Might smooth things out in the rear.
Opps you're right I had it backwards from my first statement, the higher the duty cycle % the better. Basically the higher the duty % the longer you can run the compressor before it needs to cool down. My 400c compressor is also pretty hot after I fill all 4 of my tires from 20lbs to 35lbs.
I went from the 400p to the 440p lol. The 400 being full duty cycle, but super slow. The 400 being 33% but still allowing to fill 2 sets of 33"s from 18 to 40lbs.
My single arb is 30% I think and we aired up two trucks, one with 32s and one with 33s no problem. I thought I read somewhere that the % is basically how long it can run straight before needing an hour rest. So 30 mins straight to an hour rest. Nice thing about the oba is that it stops between tires. So gets a quick break.
Sent from my Nexus 6 using Tapatalk
I was able to do 2 set of tires also but damn the compressor was so hot after! I actually had 2 400c compressors in my Audi so when filling my 5 gallon air tank in the trunk it would only take 40sec or so. I just wanted the tank to fill as fast as possible. I sold my one for $80 and re purposed the other one into a portable unit.
That's not exactly true, you want to look at the duty cycle also. I have a Viair 400 (similar to 88P) which I re purposed from my air suspension from my Audi. Both 88P and 90P compressors you're looking at are good up to 120 max psi meaning they can pump up to that amount, so either will work for all sized tires.
The duty cycle shows how long it can run before it needs to be shut down from overheating. The lower the % better, meaning the one with lower % can be run longer before it overheats. Generally the lower % pumps less air and will take longer for each tire to be filled. Think of the 88P as a sprint racer and the 90P as a marathon racer.
So both would be fine filling up 4 tires after airing down for a trail run but if you plan to let someone in the group borrow it to fill up theirs then I'd get the 90P as it can run longer without overheating.
I have the 88p and I air up from 18psi to 40 psi on 255/80/17 (skinny 33's) in about 4 mins per tire. For the price it's a decent compressor. I use an ammo can to store it since it doesn't come with a bag. They get super hot after use so an ammo can is better than a nylon bag anyways IMO. The only word of wisdom with the 88p is to check your psi manually with a decent air gauge as you near your desired psi. The one on the compressor isn't very accurate and I'm usually 2-3psi lower than what the built in gauge is reading. I bet most economy compressors are similar in that regard.
I haven't tried the 90p either, but I bought he 88p based off the tire size recommendations on Viair's website. My understanding about duty cycle is that the higher percentage means the more minutes per hour it can be run before needing to cool.
good info! thanks for sharing. i'm in the market for a compressor as well and this helps. any other compressor recommendations out there?
I'm glad the question about compressors came up. I've been looking at compressors, as well. I don't want to drop to cash on the double ARB compressors which seem to be highly regarded, so I'm trying to narrow down some other options. I've read mixed reviews on the Viair compressors, including the OBA packages, due to being slow (really?). While not as fancy as the ARB and Viair compressors, I've also read very good reviews on the 1.5 gl Puma compressors. There is a lengthy thread on IH8MUD about the compressors - guys using it as a "portable" compressor and also separating the small tank and compressor to make an OBA set up. It has a higher CFM than the single ARB and Viair compressors. Then again, I'm not sure how the stated specs for these compressors play out on the side of a trail, especially with hot, dry, and dusty conditions in SoCal.
Which model do you have? It looks like nearly all of the single ARB compressors are 50% duty cycle, but I was curious how long it takes the single ARB to fill the tire sizes you mentioned.
CKMA12, looks like it is 50% duty. so 30 mins on, 30 mins off. It does also get a quick 5-10 sec break in between tires, hah. Takes me about 2 mins to air up from 18-40 psi on a 255/75/17.
ARB On-Board High Performance 12 Volt Air Compressor (CKMA12)
This is a temporary spot until I build the cargo box and then it'll have it's own section for the compressor, hose, and accessories.
For 300 bucks it should blow you between tires and not need no damn break ...holy crap.
I have a Viair and yes they are sloooooow....
240 shipped on a group buy deal and another 30 for the air up package and hose, 30 for the air gauge. Not terrible, but I do love it. Plus it can handle dual lockers when I'm ready.
Yeah I remember you got it from Chase at MRT.
Whys that ...shady?
Go check out the Group buy section, a bunch of people got burned on their parts although I think at this part everyone has gotten their refunds. I still haven't gotten a spanner and I've been told 4 times + have a tracking number that's 2 weeks old, but haven't gotten anything.
2001ATL
