So Cal 4Runner BS Thread
When I talked with Metaltech he said I was too heavy to make use of those springs and that I should go a more traditional route, or look at custom if I cared to.
When I talked to any vendor or manufacturer they say I really should run 2.5s (except bilstein-they say 5100s should be fine).
Man I told you all the exact same shiiit brotha, and what your best options are. Coming from someone that runs a heavy ass rig and height to boot...and when he said traditional it was just as I was explaining to you
But in either option there is one common factor, to give you a baseline to start from ..that your rig will need 2.5's in the rear no matter what to get what you want and looking for, for it to be done correctly and for you actually feeling/being satisfied..that's a fact.
I ran 5100s for about 2 months before I got rid of them. Such a terrible ride. Anything you put in the back is going to be an improvement over them.
I've not had such a bad experience with mine, but my understanding is that the SS 5100s are a bit different than the standard 4runner ones.
I feel you wanna do the rears with that kind of set up you have a couple options
One would be to add shock hoops in your upper rear wheel Wells giving you a higher mounting point for the shock allowing you to fit a true extended travel shock with an actual reason to even need a rear shock with resis in the rear of our rigs will also allow for a 2.5 w/res and 14+ of travel also would be using a different type of shock in any style of shock you choose ..we currently use shocks with top stem mount for bolting down the shocks top mounting point. You would need to get shocks with eyelit mounting pointing like the shocks on the rear of a Tacoma or tundra etc..basically we bolt on vertically they bolt on horizontally.
You need help installing any of the suspension you picked up let me know I knock that shiiit out right for you.
The other option is relocating the bottom shock mount/ add a completely new mount actually, and this would be mount inward the direction of your diff creating a farther mounting point and angling your shocks allowing for a longer shock travel length
Then there's doing a custom fab canteliever rear suspension you can have built
Starting at 5k to adventure down that path.
The 5k option-as nice as it would be-is definitely out.
I'd definitely be interested in some alternatives in terms of either shock hoops or relocating the mount towards the diff. (I loved the writeup on that here: Toyota 4Runner Suspension Upgrade).
I've also seen pictures of some 4runners using a ford shock tower to get a bit more height. That seems simpler, so it obviously must have some drawbacks.
That question always comes down to the fact that I don't know how to weld, and though I'd like to learn-I think that attempting to learn on my shock mounts is probably a bad idea.
Between shock hoop/shock tower, or mounting them in towards the diff what would you say the benefits/downsides are to each? Also, what sort of costs for each of those?
LOL. Yeah, I remember what you said man. To be fair, I talked to Metaltech months ago about this. You're right though, I need 2.5s in the rear. Now I just need to convince my wife that the little 2.0s aren't going to be any good, and that I really need to spend another grand on shocks (if I can get lucky with a craiglist find), plus whatever it will cost me to a mount solution that works for me.
Thanks man.
I'll definitely hit you up for some help getting the fronts installed in the next month or two (got to get send them out to have adjusters added and get them rebuilt). Is the rear something you'd want to tackle as well?
Well... my alternator crapped out on me.
In other news advance auto has a 20% off sale that is good through tomorrow. I like spending less money. Promo code: F75
BTW, how come no one told me about the September run? I'm gone for a week and you guys forget about me?
Remember our brains have been melting here for the last week while you were splashing around with turtles in Hawaii ..you so politely forgot to invite all of us too?! Diiick!
So we'll call it even ...
Shhh! September run is super secret. Only post it on five different message boards so JBurt doesn't find out about it. Someone fry his alternator so he is to busy to notice the run.
the fuxk is this bumper
anyone in the L.A. area who owns a rola rack or the yakima load warrior???
I'm driving up to Norcal in September and would like to get a basket to carry a few extra things :naughty:
If you do own one, I wouldn't mind checking it out in person to see the fitment and whether I like how it looks :p
Got my Icon stage 7 installed today!!! Big props to [MENTION=109205]mwray8909[/MENTION] for installing it!!! If you guys are looking for a guy to install your lift, Matt is the man!!!!
Went scouting this weekend in calico. Odessa canyon took me for a wild ride (I'll post video and pics of that in the calico thread soon) hardest trail I've done to date and we actually had to turn around. Took some damage.
But you know what they say. When life gives you lemons, you upgrade to steel.
Sent from my Nexus 6 using Tapatalk
which group had the rollover?
it's popped up on non-toyota social media too lol
e-famous for the wrong reason
I believe it was a crew from Orange county
Sent from my SAMSUNG-SM-G890A using Tapatalk
Was it a silver 3rd gen that slowly flopped on its side?
WTF happened?!
WTF happened?!
Mostly driver error. Backing out of a waterfall that I couldn't make I didn't realize I was as close to the wall as I was. That was the rear end. Driving back down the trail there's a tight turn around a boulder. I tried to pivot off my slider and basically missed. Hit the side. That was the front bumper. Trying again, I got too close to the boulder I was trying to pivot off and high sided on my slider with my wheels turning the wrong way and couldn't correct. Got yanked off the boulder which yanked my steering wheel. That was the thumb (sprained). It was a hell of a weekend.
Damn that sucks. Glad it's not worse. I like your lemon comment.
Yeah. I was already planning on upgrading the front bumper in like October/November so I guess it kinda panned out. Called Demello this morning, they had material for a single hoop in stock. Burned it together, and let me pick up 2 hours later. Bloody amazing. I was told there were only 3 in stock and if I had waited until later I was looking at a 6-8 week lead.
Oh, I was going to make a joke about using "the stranger" one too many times but better late than never! At least you drive an auto, I would have a rougher drive home than you with the 5 speed and 1 gimpy hand.
AndiGarage
