So the 4runner fails headlight tests with a "poor" rating
Got the XD kit, looks well made.
Question,, several folks have said they did not use the included relay harness as the HID's are only 35w. It would sure make the installation much easier. Any thoughts on leaving out the relay?
I had them installed then removed them to clean up wiring when I swapped batteries, I noticed no difference
Sent from my SM-G930V using Tapatalk
Daniel Stern Lighting Consultancy and Supply
Read that website before doing anything with your headlights.
The number one thing that helped me was to turn OFF the foglights. The way the human eye works, 99% of fog lights brighten the road up close, which causes the pupil in the eye to constrict and lessen the eye's ability to see further in the dark.
I corresponded with Daniel via email and he recommended the Philips H11 XTreme Vision bulbs for the low beams for the 4Runner.
I very much like the lights on my 4R and I do a ton of desert, mountain, and backroad night driving. I had to lower my lowbeams when I first got the truck after I got a few flashes.
I did order the H11 Xtreme visions for my 2010 on Amazon for $25/pr. Unfortunately, they've been back-ordered for a month. Still thought it was worth the $ to give them a tryout.
So based on the posts I've read, I think I'm going to order the XenonDepot H11 HID Conversion Kit (4300K Phillips Bulb). My question then stands at do I want to get the CANbus or not? And what is the difference between them? I've got a 2015 Trail that's completely stock at the moment.
The other option I've looked at (saves $$) is the HID Extra kit. I'd love suggestions/experience for either!
Edit: I'm also going to be running them without the relay as it isn't necessary for my T4R, unless someone corrects me otherwise.
no canbus on low beams, you won't need the relay with the 35w kit
canbus is basically a network the various controllers use to communicate, your high beam is using that to control high beam and drl instead of a traditional relay setup
for that kind of money id recommend LED h11s. The xtreme vision bulbs have a very short life at 300 hours.
I ordered these "XenonDepot H11 HID Conversion Kit (4300K Phillips Bulb)" as well and they are fantastic. This is the route to go! And yes no relay to add, enjoy the new setup!
RetroRod
They work fine for those of us that dont need glasses. I swear HID's look like high beams. Some of you are blind as bats
Yeah, the obsession with high-intensity lights dumbfounds me. Of course everyone wants more light traveling alone on an unlit highway at night, but in those cases you can actually use the high beams. But in normal driving, I don't see the appeal. I drive with my interior lights down anyway; probably a good habit learned from other activities.
At any rate, not like most people probably read the report but the data doesn't differentiate* (i.e., it's useless). I'll highlight three interesting paragraphs.
When headlights produce a lot of glare, it doesn't necessarily mean they do a good job lighting up the road for that vehicle's driver. When equipped with halogen projector headlights, the Edge and the Buick Envision would rate poor based on either glare or visibility alone.
More than half of the 79 headlight variants evaluated have too much glare. In 17 of those cases, the headlights would be rated poor based on glare alone. Complaints about glare from oncoming headlights are common, research by the National Highway Traffic Safety Administration indicates.
"Managing glare can be more challenging for taller vehicles like SUVs and pickups because their headlights are mounted higher than on cars," Brumbelow says. "Better aim at the factory can minimize glare."
So it's not necessarily a lumens issue, it's just how you use it? I've heard that one before.
*Ok, I see there are results for 4R vs Rav4; interesting ratings, would like to see all of that tabled; 4R gets a "some glare" rating as well
Yes, the irony/simplicity of it is that our eyes work better in the dark with less light. Not sure HIDs do much to help, and anyone "upgrading" their interior/dome lights might be making their situation even worse.
RetroRod
Sounds great! I'll be placing the order this afternoon, can't wait for delivery. Thanks for the help!
runer4life-albums-my+pix-z-picture37477-i-also-installed-h11-xtreme-hid-5000k-digital-conversion-kit-its-best-upgrade-imo-no-i-do-not-get-high-beams-thrown-me-oncoming-traffic.jpg
I also installed an H11 Xtreme HID 5000K Digital Conversion Kit. It's the best upgrade IMO and no, I do not get the high beams thrown at me from oncoming traffic.
upgrading interior lights is dumb, its already too bright inside as it is from the factory (they should have kept the orange lights), but HID's in the projectors aren't over flooding the foreground like a light bar would, they are putting light downrange.
there are plenty of times on unlit interstates or highways where there is too much traffic to consistently use the high beams, but the rate of travel is too high for the factory low beams because they suck so hard
I really don't think they are that bad. I'm coming from a Subaru BRZ with HID's. Would they be better? Of course. But its not bad enought to me to just spending a decent sum of money on a proper retrofit. I've been down the HID in reflector housing road before, but I'd rather have people driving towards me be able to see.
Yeah reflector housing not much you van do except better bulbs and make sure they are aimed properly
This is exactly the reason why I don't see the point of most people's obsession with HIDs or super bright lights.
Except they are, they're pushing too much bright light in a very concentrated area. Every picture I see of "before/after" with HIDs the background becomes almost pitch black outside of the light's path. While some of that is because of how the camera captures light/images, the same still holds true in the real world. I've seen plenty of HIDs where they light up the front of the vehicle but above the cut-off is just pitch black and to the sides of the vehicle where light doesn't reach it's pitch black. You would easily miss a deer or object moving across the road because the light overpowers your eyes ability to adjust the stark contrast.
One thing about high-beams that most people don't realize is that they're not exactly brighter, but rather they aren't as restricted. If you ever notice the light spread between Low & High, you'll see that the High Beams just light everything up, while Low are regulated to avoid glare and such.
Additionally in regards to the "Fails Headlight Test" their testing methodology isn't very clear. It seems as though they're attributing scores to "glare" and "ability for the lights to curve", ect. So at a certain point, is the 4Runner losing because it's not burdened with fancy bullshit or because it's light output and pattern is genuinely not that good?
The projectors I run in my 4th gen with the Sylvania "ZXE" bulbs do a pretty damn good job lighting up the road and not causing the background to not be visible.
Post Note-
The main thing about LEDs I have heard so far is that they are too focused and trying to get them to spread/scatter the light better has been challenging for an OEM Headlamp solution. I have a cheapo adjustable focus flashlight that you can adjust the lens on to a point where I can see the actual LED on a wall. Like I can see the LED die shape projected on the wall down to perfect angles and the small voids inbetween the LED chip itself; I guess LEDs are more laser-like with light emission vs. a more scattered wave that a bulb produces?
