SOcalTrail's 2011 Trail Edition Beast Build Thread
Bumper / Tire Carrier Update
I got the spindle mounted, the swing out, and the latch assy. all buttoned up yesterday. All that's left is to mount the tire and the hi-lift which I have already drawn up, just waiting on more 2"x2"x.25" tubing to finish the project. After that I have to make the trim pieces to cover the corners and send it all off for powder coating! It is all VERY VERY BURLY!!!. I weigh 190 lbs and can bounce around on the swing out with it in the extended position with no bending or bad stuff going on. When in the latched position, the Bear Jaw latch is backed up by a .375" SS Pull pin rated at 20,000 LB shear strength and the downward weight rests on a piece of machined delrin. No weight exerted on the latch when its closed, very trick. Everything is plated, used all .375" steel and .75" steel to mount the components, all waterjet cut.
Here are the pics, lots of nice TIG welding here!
How did I miss this update!? Must have been too many tire threads this day or I maybe I was actually working that day.
I cant wait to see it back from powder coat.
It turned out great, glad you took your time building it to do it right.
***Bumper Update***
Got some more square toooob and got my tire carrier almost buttoned up. Just a few more little details and the carrier portion will be done.
Still have to:
-Re-locate the backup camera (thinking about putting it smack in the middle of the swing out in a little armored housing, I bought an aftermarket Alpine camera)
-Make a new license plate holder. Gotta decide if I want it on the spare or mounted to the Gobi ladder, I have it temporarily zip tied to the Gobi ladder and it actually fits there well.
- Weld in the studs and mount pads for my Hi-Lift, It is going horizontally along the swing out arm.
- Add in my redundant safety catch. Even though the "bear claw" latch I am using is very strong, I want to have a redundant safety so I bought a 3/8" 20,000lb QD push pin that I need to mount.
- Last but not least, I need to finish making the trim pieces. I had to wait until everything was welded up before I tackeld this.
- After all is done, Powdercoating!!!!
PICS:
file-83.jpg~original
file-87.jpg~original
file-88.jpg~original
file-90.jpg~original
file-91.jpg~original
Well if you ever decide to make another light mount, I'd be interested. Your set-up is by far my favorite location for some add'l off-road lights.
Seriously, how much do you want to make your behind the grill magic happen? That is the slickest, most subtle and legit way to add extra lights without the luxury of a Gobi rack that I have seen. Name a price :P
TPatt88
That rear bumper is stunning.
TPatt88
I'd be in for a bracket. Found a VisionX dealer with a guy that thinks he might be able to fab one, but no firm "yes" from them yet...
SOcal - what are the chances there are specs for that bracket laying around?
That rear bumper is stunning!
Thanks!!! Still knocking out the finishing touches!
I'll check my folder of CAD files and see if I still have them I lost a whole bunch a few months back during a computer transition at my company. Big bummer!
Add me to the wait list if you ever make some for purchase... Keep in mind I know you had to massage the ac lines and tweak some stuff on the go , so I wouldn't be expecting it to be 100% plug and play.. But it would still turn out better then anything I could produce in my chop shop... That also goes for you aux battery tray... I have no clue why you insist on enjoying your weekends instead of making me parts. Not cool brah
Maintenance!!!!
I spent all day Saturday doing some maintenance on the rig. At 40k miles, I performed the following:
* Changed engine oil - Mobil 1 0w-20
* Changed oil filter - OEM toyota
* Installed Fumoto drain valve on oil pan.
* Changed front and rear differential fluid - Redline 75W-85 GL-5 Gear oil
* Changed T-Case fluid - Redline 75W-85 Gear oil
* Cleaned AFE Dry Engine Air filter
* Changed cabin air filter - OEM Toyota charcoal filter
* Cleaned and re-greased all greasable poly suspension bushings with SuperLube
* Cleaned and re-greased the slip yoke and all greasable u-joints.
* Re-painted wheels with
* Touched up sliders
* Washed and waxed with Meguiar's Ultimate
+ I had a bit of time to do a little more work on the bumper. I made the "stop bumps" for the swing out latch and fabricated the plates for my safety pin secondary latch. Also came up with a nifty mount for the Hi-Lift up on the Gobi. Pics to come!
love the rear bumper. i got a similar rear bumper and will need to have the swing out mounting point welded in like yours on the rear outside area. any chance you can post some better pictures. thank you
nice job on the maintenance work
I'll get some better pics up today.
In the meantime, here is some fun testing the flex with the fork lift.
file_zpse0fbe3b3.jpg~original
file_zps3c423b95.jpg~original
file_zps2d14f614.jpg~original
ToyoTech-
Here are some better pics of how I welded the swing out spindle to the bumper. On the back side of where it is welded there is a 3/8" plate permanently welded to the frame that those 3/8" bolts go through. There is still a piece of 1/4" plate that is going over all of this. Its incredibly solid!
Pics look like crap, the bumper needs powdercoating, it only has a light coat of Rustoleum for the time being to keep it from rusting too bad.
file_zps7cc444b7.jpg~original
file_zps60af1bef.jpg~original
file_zpseedc02d0.jpg~original
Finally got my Hi Lift mounted how I wanted it!!
I never liked Gobi's solution to mounting the Hi Lift Jack on the side of the Stealth Rack and I have been looking for a store bought solution for quite a while. I ended up coming up with a homebrew solution that I think is pretty darned nice.
The parts I used are all readily available, nothing custom, and all reasonably priced! All parts were purchased from McMaster-Carr. (McMaster-Carr)
2- Rod-Mount Block-Style Sanitary Clamping Hangers (Part #3063T14)
2- 316 Stainless Studs - 3/8"-16 Thread - 1.5" Long (Part #98865A525)
One pack of stainless 3/8"-16 Wingnuts (Part # 93575A031)
I opted for all stainless stuff which bumps the price a bit, if you were wanting to save a few bucks, going with zinc or cad plated hardwear would work pefectly fine as well.
The studs line up perfectly with the holes in the Hi Lift as you can see; that is just a plain old run of the mill 48" Hi Lift. Everything is super solid and strong. I have some aerosol plasti dip that I plan on spraying the beige colored plastic with to hide it a bit better.
file_zpsf2081542.jpg~original
file_zps1c96db67.jpg~original
file_zpsd7769ce7.jpg~original
file_zpsfb3996df.jpg~original
file_zpsf63d2fe1.jpg~original
thank you so much for the pictures. love the build so far. i would have a 5th gen TE this year after one of my cars got stolen but didnt come in WHITE. so ill have to wait and see lol.
Man that is one sick 5th gen! It really is a beast and builds like yours keep 4runners on the map. Im also diggin all the lights! Now i realize just how serious some people on these forums really are. I gotta step my game up! hahaha
Thank ya sir!
Did you take your front sway bar off?
Yesiree Mike! - My front KDSS bar has been "missing" for over a year now. I took it off and never looked back. Im actually looking into ditching the rear KDSS which doesnt do a whole lot now and fabricating in a custom Curry Anti Rock rear sway bar similar to how these guys did it here:
Building A Custom Currie Antirock Sway Bar - 4 Wheel Drive & Sport Utility Magazine
Not a problem. I still find it strange that the TE isn't offered in white. My dad had the same reservations when he looked at the TE's.
Jhunt
