Sold! 1998 T4R LTD with E-Locker $5,400 Located in Sun Valley, Idaho
Ser1clymb
1998 4runner Limited in Evergreen Pearl with automatic transmission, 4 wheel-drive, and locking rear differential. There are currently 279,000 miles on it, no accidents, and original engine, frame, transmission, etc. It comes with leather interior, steel skid plates, 33” Mickey Thompson Baja ATZ tires, upgraded suspension, and a clean title in-hand. Timingbelt, water pump, and drive belts replaced in April 2020 with oem parts. I have documented and performed the maintenance and upgrades myself with with oem toyota parts. I am happy to provide more details and images, but just purchased a new truck and wanted to get this listed.
VIN JT3HN87R6W9010113
More images can be found here
4runner For Sale - Album on Imgur
Differential Fluid
Rear- Valvoline 75w-90 LSD Synthetic
Front- Valvoline 75w-90 LSD Synthetic
Transfer Case- Lucas 75w-90 synthetic
Coolant- Pentofrost/Toyota Red
Transmission- Red Line 30504 D4 ATF
Power Steering- Napa Dextron3 ATF
Completed Maintenance
272,000 miles- air filter, fuel filter, PCV valve, PCV hose, PCV grommet, radiator flush, upper & lower radiator hoses, power steering flush, throttle body cleaning, fuel system cleaning (sea foam)
272,000 miles- front brake pads, headlight assemblies, headlight bulbs, painted front bumper, front and rear speakers, sound deadening
272,200 miles- upper ball joints, lower ball joints, outer tie rod ends, sway bar end links, sway bar bushings, steel fixed brake lines, alignment, oil change, brake bleed, Airaid M.I.T intake, cruise control, throttle, and transmission kick down cables tightened
272,250 miles- intake plenum gaskets, left and right valve cover gaskets, spark plugs and wires, rear differential flush, new rear differential fill and drain plugs, coolant flush, passenger side CV axle, painted rear bumper and panels, new rear bumper brackets
272,300 miles- JB Weld leak on rear differential, flush rear differential, replace rear differential breather, flush transfer case, flush front differential
272,350 miles- Replace upper control arms, replace upper ball joints, front passenger side CV oil seal on front differential, front alignment
273,500 miles- Replace driver-side CV axle, replace radiator, flush radiator
275,163 miles- Flush coolant, replace upper/lower radiator hoses, replace radiator cap, replace thermostat, replace O2 sensor upstream, replace vacuum hoses, replace air filter, RCI skid plates front and transmission
275,233 miles- replace rear shocks and coils, replace sway bar end links in front and rear
275,246 miles- drain/fill rear differential oil (valvoline 75w-90 limited slip synthetic), repair rear differential leak, rust treatment
275,258 miles- replace rear lower control arms, rust treatment under chassis, reupholster both front seats (bottom/back), replace seat track bolts, replace oil pressure sensor
275,251 miles- drain/fill and flush transmission fluid, lubricate driveshaft and front upper ball joints
275,710 miles- drain/fill front differential fluid, replace driver side axle shaft seal, top off coolant, adjust upper control arm and upper ball joint (driver/passenger), grease upper ball joints
275,962 miles- replace rear upper control arms, fix/grease driver side front and rear locks, paint roof rack and rear fairing
276,278 miles- replace throttle body gasket, replace IAC valve gasket, clean throttle body and IAC valve, replace throttle position sensor, replace front shocks and coils, fuel system cleaning,
276,700 miles- rubberized coating in wheel wells, replace steel rear heater lines, replace heater control valve, replace heater lines and clamps
276,861 miles- replaced rear sway bar end-links, replace fasteners in front/rear fender liners
276,877 miles- 99+ center console swap, front alignment, oil change, new wheels mounted and balanced, UCA adjusted, pinch-weld mod and fender trimming
277,405 miles- replace front coils
278,181 miles- replace rear roof seals, replace driver side front door seal
278,205 miles- replace tailgate relay, replace tailgate wire harness, replace tailgate window motor, replace tailgate wiper motor, replace tailgate latch, replace tailgate license plate lamps, flip trailer hitch
278,476 miles- replace timing belt, water pump, thermostat, idler pulleys, replace crank pulley, replace crank bolt, clean lower engine block, clean crank sensor, clean cam position sensor, replace coolant temp sensor, replace coolant temp sensor wire harness, clean throttle body, replace heater hose, coolant flush, clean fan bracket/clutch, clean MAF sensor, replace power steering belt, replace A/C belt, replace alternator belt, replace spark plugs, replace spark plug wires, replace timing cover gasket and bolts
278,622 miles- Replace steering rack bushings, replace front lower control arms, replace front lower control arm bushings, replace front lower cam adjusters, rust treatment for front wheel wells, rubberized coating in wheel wells and fenders, replace fasteners in front wheel well fender liners, replace lower shock bolts, wheel alignment
278,628 miles- replace front differential arm bushings
