(SOLD) 99 Limited 4runner|10,000 OBO|Tucson, AZ
Vargntucson
SOLD
1999 Limited Toyota 4runner 4WD, E-Locker equipped
$10,000 OBO
222K miles
Tucson,Arizona = No Rust! ALWAYS garaged at home and covered parking at work.
Vehicle is very clean, well maintained and in great shape.
Suspension
  • Radflo 2.5 Adjustable, 0-3.5 inches, Coil Overs
  • Sonoran Steel Fabrication L.L.C. Front Differential Drop Spacers
  • WabFab Sway Bar End Links
  • 1 inch Roger Brown Body Lift
Sonoran Steel 1.2 Lift Kit Complete
  • Toyota 80 Series Land Cruiser Coils
  • Sonoran Steel Fabrication L.L.C. Adjustable Trac/PanHard Bar
  • Sonoran Steel Fabrication L.L.C. Extended Bump Stop Adapters with
  • Daystar "Competition Style" Bump Stops
  • Sonoran Steel Fabrication L.L.C. Rear Sway Bar Adjustment Brackets
  • Sonoran Steel Fabrication L.L.C. Braided Stainless Steel Extended Brake Line
  • Sonoran Steel Fabrication L.L.C. Brake Line E-Clip
  • Sonoran Steel Fabrication L.L.C. Drive Shaft Zerk Plug
  • Sonoran Steel Fabrication L.L.C. Parking/Emergency Brake Bracket
  • CAMBURG, 1.00 Performance Uniball upper Arms
Tires/Wheels
  • BFG ALL-TERRAIN T/A KO2 – 285 70 R17 (33 inch tires)
  • BFG MUD-TERRAIN T/A KM2 – 285 70 R 17 (33 inch Spare Tire)
  • KMC Enduro Rims
Engine
  • K&N 57 series Air Intake
  • K&N Dry Charger
  • Magnaflow Muffler
  • Yellow Optima Battery
Interior
  • 1st Generation 4runner Roll Bar
  • LED Interior Lights
  • Rear Mod Switch for liftgate window
  • Husky floor & cargo Mats
  • Alpine head Unit & Speakers
  • Alpine 4 channel power Amp,
  • V12 Series MRV f305 Amplifier
Exterior
XRC Smittybilt Synthetic Winch
  • Rear Custom Bumper
  • Yakima Load Warrior (Extension Included)
  • Yakima Control Towers
  • Yakima Spare Tire holder
  • Yakima Bracket for 48 inch X-Treme Hi-Lift Jack
  • Yakima Extension, & two Bike Racks
  • 2 Hella Black Magic Driving Lights
  • Integrated Rock Sliders
  • Tacoma Whip Modification
  • Front D Ring Shackle Mounts * Tow Hook Replacement *
  • Smittybilt Receiver Hitch D-Ring Shackle for rear hitch
  • 4 pin trailer connector
  • 42 inch Low Profile LED Curved Light Bar (I think it is 42 inches)
  • Unique TJM T13 Front Bumper. Steve from Sonoran Steel said that only a few made it to the US.
*Wired for lights on the roof rack and for lights mounted on the rear of the truck.
*MAINTENANCE*
-Mobil 1 synthetic oil and premium gas since 2007
  • Spark Plugs, coil packs (OEM) & NGK Wires, 2019
  • Valve Cover Gaskets (OEM), 2019
  • Front diff bracket DURO Bumps bushings, 2019
  • Brake Booster (OEM), 2019
  • Cleaned Mass Air Flow, 2019
  • Cleaned Throttle Body, 2019
  • Grease Drive Shafts, 2019
  • Rear brakes replaced (OEM), 2017
  • Front brembo rotors, (OEM) pads, 2017
  • Starter (OEM), 2016
  • Steering rack, (OEM), 2015
  • Front/Rear diff. and T case oil change (redline synthetic, 75w90), 2015
  • Transmission oil change (redline synthetic MT 90), 2015
  • OEM Toyota CV axle, (OEM), 2015
  • New OEM Lower Ball Joints 2014
  • Fuel filter, 2014
  • Alternator replaced, 2013
  • Timing Belt, (everything OEM) 168K miles, 2012
  • Water pump, Thermostat, Alt belt, PS bel, A/C belt, idle bearing)
  • Replaced radiator with a Koyo Radiator & Toyota Red, 2012
  • Front Wheel Bearing (Inner,Outer Seal, Snap Ring, Spacer & Skid Control Rotor)
  • Rear Wheel Bearing (Type S Oil Seal for Inner Axle & Type K Oil Seal for Outer Shaft, O-ring, Retainer, Skid Control Rotor, Snap Ring)
2001ATL
