**SOLD** JBA STD High Caster UCA'S
dropspace
** SOLD **
I have a pair of JBA High Caster UCA'S for sale. Model JBA-7.0.HC - work with 4th or 5th gen + FJ Cruisers
Pics at: JBA UCA'S - Google Photos
You are going to want to get new bushings as these are kind of worn and JBA changed their bushings so that they don't come off the arms after they get worn.
Also, the ball joints aren't seized but I would probably replace those too as the newer ones don't get so corroded. Easy to bolt in.
I had some rubbing issues on my setup so I changed to a set of boxed arms that have a bit more clearance. As a result, there is some rubbing where the powdercoat came off.
Basically, if you want a cheap set of perfectly fine UCA's get these, powdercoat 'em get new bushings and ball joints and you have a brand new pair.
$150 + shipping
matisgugle
