Sonoran Steel Install
I managed to install the SS 1.2 kit with hardly a snag! The R side sway bar mount bolts sheared off when attempting to remove them, so I had the extension plate welded on.
J.S., happen to have any photos of what broke and how you welded to fix it?
Still trying to figure out how to add images to a reply like this. Anyway, the rear sway bar is bolted to the axle at both the right and left side. The SS kit requires the installation of extension plates at these sites since the axle is dropped. The two little bolts strapping the right side of the sway bar to the axle broke off due to being rusted in. It's a common issue and easy to fix. I just drove it to a local mechanic who charged $30 to weld on the affected extension.
REE
