Spark Plug Questions
OrbeaRider
I've got an 03 Sport with approx 110K miles on it. So far as I know, it has never had the spark plugs replaced. Thanks to the forums I decided to stick with either NGK or Denso and, after going to several parts places, ended up with a set of Denso Platinum TTs. However, after checkinig the owner's manual, it says that I should only use Iridium (sp?) plugs in the car.
So ... will I have any problems running the Platinum TTs until I can afford to get something better (I'm unemployed right now)? Also, these TTs are gapped at .40 ... is that the correct gap?
Thanks a lot for your help!
JT
Most of the DIY plug changes here have taken place using the regular Desno plugs from the dealer. Thats what I used. New plugs from the dealer (pre-gapped to .40) were like $25 for 6. The install cost me 40 minutes and two Coronas+ 2 Lime slices (:beer:)...You can tell if the plugs are the originals if the driver's side are all Denso and the passenger side are all NGK (or it might be the other way, i forgot), either way most if not all who have changed their plugs have gone to all one type and most have gone all Denso. (BTW: this is for the V6.)
:iagree:
And V6 or V8??? :confused:
