CitadelBlue
I have a 2002 V6 with 120,000 miles. Any recommendations for source and brand/part number for replacement spark plugs?
Ken
Ken
That very well could be your issue. You should only use dual electrode plugs in the 3.4. NGK #TE66 or Denso #671-6182 ONLY. There's actually a sticker on the front of the engine that says so (if it's still there on yours). Duralast is junk too, you should only use NGK or Denso plugs and wires (and all electronics/sensors). Here's a pic of the sticker:
Toyotas DO NOT like Bosch parts. If you use only NGK and/or Denso parts, I guarantee your 4runner will run longer and healthier than if you don't. The proof is in the sheer amount of people who have problems with other brands. Check out sparkplugs.com for all that kind of stuff, they're way cheaper.
I really, really think it's those cheap Autolite plugs and Duracrap wires you got in there that are causing your miss. In this engine, the plugs fire on the comp and the exhaust stroke so single electrode plugs wear out twice as fast... and even the duals are supposed to be changed every 24K. Try that 1st.
I will never buy anything Bosch ever again in my Toyota. I cooked one of their plugs a few years ago after 1 year/12K: (yes it was a single electrode)
Humm... Am I reading/searching this wrong? SparkPlugs.com don't seem to list either plug ......NGK #TE66 or Denso #671-6182
They list:
Denso Iridium plug 5303 IK16 $9.99
Denso Platinum TT Plug 4503 PK16TT $3.26
NGK IX iridium 5464 BKR5EIX-11
They list:
you can go to your auto parts store and they'll have it most likely. go with denso if possible and if not NGK will be the next in line. sucks for me because i didnt get twin electrode..o well i'll replace at another 20k
Something got lost in the translation of that qoute (I was originally responding to what wires someone should buy), so those part #s are for the wires. The OEM plugs are:
NGK: #BKR5EKB-11 or
Denso: #K16TR11
Sorry, hijacking!!
The plug wires (NGK for instance) only come with 3 wires... so one side goes on the coil pack and the other onto the plugs?
wires connect the plugs. 3 wires so each wire connects 2 plugs. be careful though dont pull all old wires out at once. if you remove one wire at a time you'll see they are connected to a plug at both ends...do one wire at a time removing only one wire at a time or else you'll get a misfire
