chillwihll
what are the colors of the wires for each front speaker in the 4th gen sr5?
ZOSO Runner said:This is for the 6 speaker system....
Harness behind the HU:
Gray=ACC Power
Blue/Yellow=Constant Power
Brown=Ground
Pink=Front Left +
Purple=Front Left -
Lt Green=Front Right +
Blue=Front Right -
Black=Rear Left +
Yellow=Rear Feft -
Red=Rear Right +
White=Rear Right -
For the tweeters in the Front doors:
Left:
Red/Blue=Left side + input
Pink=Left side + output (then goes to woofer + side)
Blue=Left side - input
Purple=Left side - output (then goes to woofer - side)
Right:
Red=Right side + input
Lt Green=Right side + output (then goes to woofer + side)
White=Right side - input
Blue=Right side - output (then goes to woofer - side)
chillwihll said:I think you can tap the rears. I tapped mine back in 2002 and it's been working/sounding fine since. Make sure you run it through a hi-low converter that brings the power up to amp level input and outputs as RCA. Unless your amp has one built in.
