Speedo Woes!
Sandog53
Hello all. I have a 99 V6 SR5 2wd that I am having speedo problems with. The speedometer does not work at all. It was throwing 3 codes, 2 of which are unrelated, the third is a P0500 which shows speed sensor fault. I replaced the speed sensor on the tranny, and it did not fix it. Now, if it is throwing a code specifically for the speed sensor, why did this not fix it? If it helps, there is no abs on the truck anymore. I removed it. The techs at the dealership said this would have no effect on the speedometer. Anyone have any ideas I can try before replacing the cluster?
Has it worked since you pulled the ABS off?
The P0500 code has three things to check........it's a code for the entire circuit, not just the sensor itself.
-Speedometer cable
-Open or short in speed sensor circuit
-ECM
If you replace the cluster, you will more than likely be wasting your time and money.
Out of curiousity, what are the other two codes?
I'm about 99% percent sure the ABS and speed sensor are related on my 01'........do you have a vacuum booster behind your master cylinder?, as opposed to the abs/trac/hydraulic booster cluster f.
I talked to a toyota tech today that told me the abs and the speed sensor had nothing to do with each other. I am not sure about the brake booster, but I will check. Does anyone have a diagram on where the 2 wires from the sensor go? Do they do to the ecm or to the cluster, then maybe I can check them for continuity. I didnt think it had a speedo cable, since it has the speed sensor, maybe Im just dumb. Thanks in advance.
Don't know if it will be exactly the same as it's for an 02' but here is the FSM dl page....
Toyota Tacoma/ 4Runner/ Tundra/ FJ Cruiser Factory Service Manual Page
youngrk
