Spider Cargo Net
ProMed
Does anyone have a lead on where I could find the spider cargo net for the T4R. It is the one that spreads across the cargo area floor.
It looks something like this:
The dealer should have such a thing.
It comes with the double-decker cargo shelf, if you have that option.
Thanks for the reply toto. I do not have the double-decker since I have the 3rd-row but they are usually removed. How does the spider net connect with the third row? I have four anchor bolts at each corner of the cargo area and would like to find a net that stretch to each of them.
Not having the 3rd row option in my '03, I can't answer as to how it would fit. I have the shelf option, and it came with two nets. The 'spider' net in your pic, and a 2nd pocket type net which stretches vertically across the back. I have never used the flat spider net, but use the pocket one all the time. There are four rings mounted in the floor which the net clips to.
Thanks for the reply, I also have the pocket type net and love it. Sounds like the spider net is would work since it attaches the four floor rings. Anyone have a lead on where to purchase? Didn't any luck with partznet, suveverything, or ebay, however I may have just missed it..
Mtneer001 said:
I would like to have the pocket net that stretches across the back.
Where can you find those at?
I don't use the net that stretches across the rear floor.
Thanks...
[email protected]
I would check with the dealer. I'm not sure, but I think they come as a set with the option package. Not sure if you can get them as separate items.
PS: Just checked the Toyota main site, and they still list the cargo net as an available accessory, so you should be able to pick one up at a local dealer.
I was able to try out the double decker spider net yesterday and it wasn't a match. The lower edge of it has 4 loop that attach up under the DD, since mine doesn't have that installed it's a no-go. Plan to just measure it out and find something close.
actually i ordered that net and what i did was simple. i went to target near my house and in the camping sesction i found 2 small coleman carabiners. hooked one to each cornor and attached them to the loops in the cornors. i cant take a picture if you dont understand but thats what i did. and it works great for a good 8
months now
DionicioLives
