spitting and sputtering
farrowboy86
i have a 99 sr5 4x4 and it has 336,000 miles on it have a small oil leak so i washed the motor and when i drove it to the store the engine light came on and started to spit and sputter so i had it put on comp. and got a cylinder misfire on #2 so i got plugs and wires and dried the plug housings with air hose, i just changed the plugs on wire side not on coil side and bought single ground plugs not knowing u needed double now it is running just as bad as before if not worse suggestions please
Tx470
