Spring is here. Rust treatment time...
ellner357
Ok so I'm thinking about using POR15 and all on my frame. Lots of reading online about it. Searched the forum. I was wondering is there was a good how too thread? My main concern is do I actually have to strip off all the paint already on the frame? I just want to get this right the first time. I want to get the spray for the inside of the frame rails as well and see how much I can do to keep this things frame alive. I had an old 84 I had rust out so I'm a little paranoid.
You want to get some wire bushes and wire wheels for your drill and take off as much of the rust scale first. You can also use sandpaper and whatnot to take it down. The closer you can get to clean steel the longer your rust prevention will last.
OK, I was thinking about starting a thread on the same topic but since someone beat me to it...
Here are some of my ideas, let me know if anybody has any experience with any of it.
First water down the undercarriage with a product called Salt-Away. Looks like it'll last awhile.
Salt-Away Concentrate Kit with Mixing Unit - 32 fl oz (946 mL)
Amazon has it for $38 if you buy the liquid and spray hose separate.
I also read baking soda mixed with water will also neutralize rust.
Then I was going to apply this to the inside of the frame
Eastwood Internal Frame Coating w/Spray Nozzle
Internal Frame Coating w/Spray Nozzle | Eastwood
I ordered this from ebay for $15 a can w/ free shipping.
Then I have some Rust Bullet waiting for the rest.
I really love my 4runner and want it to last.
I'll post an update once I have time to apply this stuff.
I had the same idea of sand blasting the frame, treating it with POR15..
I checked a few videos on youtube and you pretty much get most of the rust off (doesn't have to be completely off) with a wirebrush or sand paper, wash it ,treat it with Marine Clean, wash it, apply metal ready and then apply POR 15
I used POR-15 on my entire undercarriage back in 2011. I just wire brushed everything the best I could, to remove the loose stuff. Then applied 2 coats of POR-15 by brushing it on. I didn't use the Metal Ready. It was a super messy, miserable job, but worth it in the end. It took 2 full weekends to get everything done.
It is holding up really well. There are a few small spots that need touch-up, but that's it.
RB_6-5-11_A.jpg~original
When you wire brushed it did you strip off the paint on the frame or just paint over it?
The only paint that came off was that which was already flaking off because of rust underneath it. Most of the paint was still good, and I painted over it. It would be really difficult and time consuming to remove all the paint from the frame.
I did my whole undercarriage in por 15 , great stuff ! The key to a good finished product is the prep , marine clean , metal ready , then por15. Sand blasted my rear diff and painted it .
Before pic
096CECC0-A2AE-4528-A159-D0D960AB6FB6-6313-00000349478B3BDE.jpg~original
Yeah I just wanted to be sure cause I really don't want to strip all the paint off! Talk about a lot of work!
Looks good. I wish I had a shop I could use to sandblast but it's a little to messy for any of my friends driveways.
I took the rear out and sent it to a sandblasting shop. You can bring you truck to a shop and have them blast under the truck , it cheaper than you would think .
Well dropping the rear isn't going to make sense for me since It's my DD but sending to a shop for a day isn't a bad Idea. Hmmm I guess I'll have to call around see if anyone in town does that.
I looked at mine and knew it was going to take days...if not weeks. I've undercoated a vehicle before and knew how messy this stuff is. I'm getting older...I have more money than time. So, I bit the bullet and paid like $350 and had Line-X spray my truck. Did it two years ago...still looks new. Came with lifetime warranty, free touch-ups anytime (really nice after playing in the woods/rocks), took like 2-3 hours, and the best thing...all I had to do was watch!
Now did they just spray it or did they strip it down and then spray? You take the truck to them whole? My boss did his Jeep and he had one of his mechanics split the frame and body and I had to take the frame in. Living in the Chicagoland area I wanna do mine before next winter and my truck is my DD and don't feel like fighting with the wife to take her car. Mine has moderate to average rust.
Be careful when using line-x or any other rubberized undercoating on your frame especially the guys from up north because if you have any frame rust you could be locking it in . Some of these frames rot from the inside out .
I talked on the phone with eastwood for over an hour and came to the conclusion that por15 would be very good but is a PITA to install since you have to brush it on. Eastwood is a por15 dealer too. I used 4 cans of their internal frame paint, 6 cans of rust encapsulator, and about 6 cans of extreme chassis. Also used half a bottle of PRE their prep chemical. All the products were amazing.
065_zps91f50a45.jpg~original
Check my build thread for more info and photos:
http://www.toyota-4runner.org/3rd-gen-t4rs/132960-gotopless-build.html
Robin 1082
You just drive in and they put your vehicle up on a lift and spray the undercoating on your vehicle. And when I say spray...I mean they spray everything. In my opinion, that's good and bad. The good is they can coat every little nock and cranny...the floor pans, axles...everything. Bad part...they spray everything...to include shocks, springs, etc... So you have to tell them what to cover up. The shop I went to...the guy was really cool. He let me watch him do all the prep-work...and actually I helped out. He had a wire brush that he scraped all the rusted areas to get all the lose flakey stuff off so the undercoating had a good solid surface to stick to and then he wrapped everything that you do not want sprayed. 2/3 of the time I was there, was prep-work.
The undercoating they sprayed on took like 48 hrs to dry, but you can drive it right a way. They just told me to stay off gravel roads and not to drive in the rain.
I'm sure this isn't perfect and I think a lot has to do with who does the work. If you get some rookie, who's making minimum wage, smoking dope, and could care less...I would run. If your luck, like me, and get the shop owner who treats the job like he is spraying his own car...you will be very happy!
Good luck...
Robin 1082
Good luck...
I'd love to do that. But I think I'll have to spend my time not my money lol. This time at least.
CoaterZ_FL
