Squeaky squeal question...
Guitarplaya39
Hey all. I'm not too good with words, so I'll try to explain my problem to the best of my ability!
So my 2006 Runner has a slight squeaking sound that's starting to wear on my nerves. I can only hear it with windows down, and it seems to be loudest on the right side. The noise is a slight squeak or chirp that always happens in pairs.
Like this: "squee squeak", "squeeee....squeak", "squeesqueak...".
Never just one squeak.
Conditions: speed, turning, braking, coasting, accelerating, 4wd, 2wd.... Noise is always the same. Sometimes it will change speed ("squeeee.........squeak"), but stays the same pitch. It almost seems to happen over very slight bumps or slight changes in road level, but it's so slight it might be my imagination. Doesn't make any noise while rocking the truck sitting still.
I'm kinda puzzled... What would only make a squeak noise in pairs? What should I check?
1st & easiest is to see if on your brake calipers you have 2 clips to hold pads on if not buy at napa cheap easy fix , start there & move on . Possible bushings on front sway bar ?
Cool thanks for the quick reply. I wasn't sure it was the brakes since the noise doesn't change with brakes applied. Are the rear brakes applied at the same time as the front under normal conditions?
Yes & not a squeak as much as a clicking or could be a s easy as greasing something IDK , just 1st cpl thoughts .
delislerebecca
