sr5 factory rear view camera with aftermarket head unit
So with a 2011 4runner SR5 [ No NAV / NO JBL ] straight basic, I installed a 10" android (those direct swaps, just had to swap over the 2 vents from OEM bezzle to the aftermarket bezel that housed the android 10" already. Plug and play. I put it in reverse, camera displays up on rear view mirror (OEM) as normal.
So what I would do is take the overhead console out, unplug rear view camera plug, cut back tape exposing wires.
Cut a MALE end yellow RCA/Video cable about a foot of wire behind it, strip back to expose the outter bare wire, and inner wire.
Red wire from overhead console plug > I will extend to the "reverse" wire (the typical wire on literally any double din headunit that is labeled reverse/reverse trigger type deal).
White & Black wire from overhead console plug > I will extend down to behind the headunit as well, where it will meet my Male end RCA cable. White will go to the INNER ( V+ ) shielded wire of the RCA, Black will go to OUTTER ( V- ) bare wire of the RCA.
Plugin said RCA "pigtail" I made to the Camera-out female RCA on the aftermarket headunit.
It'll work? I wont need to do anything else? Seems some people are having to use only red>reverse trigger wire on aftermarket headunit, and the black wire from the plug stating white does nothing. Some say you need all 3. Some day theres more to it than this (12V>6V stepdown / all 3, but also splicing into ground at the headunit lalala)
Just trying to wrap my head around it before I tackle this :)
Sorry to revive an old thread, its hard to find info, and when I do the next write up contradicts what I find haha... who knows... there might even be an easier way discovered by now (Considering one of the plugs going into rear of the 10" android headunit, displays reverse camera on rear view mirror when in reverse, maybe I could just tap into said plug instead of having to go from rear view mirror plug>down to headunit? :O
You can purchase a Maestro unit that provides reverse signal and backup camera video instead of hacking into the wiring harness. Plus it also provides all the I/O for power and speakers.
Can confirm that black wire to outter wire in RCA (non shielded wire), and white to RCA inner wire (shielded wire), and red wire to reverse trigger wire on the aftermarket headunit worked- android 10" "kunfine" brand or whatever. Good to go!!!
I checked everywhere for a harness. The harness's on axxess and all them are made for the OEM backup cameras that originally projected on the headunit, this sr5 didnt have a touch screen she was all manual headunit, little display for like radio station and such. So none of the harness' would work.
Took me like 45 mins between taking everything apart, running speaker wire for the 2 visuals>rca, and a remote turn on wire I had from previous car audio installs (sky high car audio cable) little overkill for remote turn on or a reverse trigger but haha, she works! Perfect picture quality, no 12>6V stepdown needed. 45 mins in and out!
But yeah I dunno bout harness' I called literally 10 places high end shops and nah man nothin u gotta do the rca trixxofthetrade hack type deal...
But yeah if maestro works thats good to know now but atleast I can verify the above worked for 2011 4runner sr5, base model no JBL no NAV.
Speaker wire+1 run of remote turn on, 3 t taps, electrical tape, solder if you're fancy on RCA side.
Does the Maestro provide the video signal? I have heard that you still need to tap the mirror and run the feed. I am looking at doing the Maestro and currently use the mirror as my camera screen.
I have a 19 so my video was in the headunit. May be different for years with it in the mirror.
The OG 5th generation are a bit of a different animal. Even the plug behind the mirror is different for the early years. I have yet to hear an answer that a usable video feed will be provided using the maestro. I would love if it did.
