SR5 vs TRD Pro Rim Specs
So it was definitely the front liner, on the driver side only, and just barely rubbing. The liner mod gave the tire a ample amount of clearance.
Bumping an old thread. I put Toyota TRD Pro SEMA wheels on my wife's new 2020 Limited 4Runner with Falken Wildpeak AT3s in P265/70R17 and am getting rubbing in reverse without going full lock.
Removed the mini mud guards from the front wheel wells and I am still getting rubbing. Had these wheels on my wife's 2012 4runner Limited with no rubbing. Not sure what has changed between the 12 and 20 models. Will investigate more and report back. May need the liner mod and/or a trim.
Did you buy oem? some of the knockoff sets are 17x8 with different offset. Should still fit on 265's though
Yes, they are OEM. Ordered from a Toyota dealer. They barely rubbed with the 265 Falkens on the driver side, and was very close on the passenger side.
Hmm, not sure than. I had 265 falcon on my stock 19 pro rims with zero rub.
Also have them on my 20 but currently on the trail rims
What trim was your 19? Maybe it is a newer Limited issue.
The trail rims don't have as much offset and are less likely to rub.
johnnya
