SRQ Fabrications Ultra4 4600 3rd Gen Build
Your welds are looking good!
Thank you sir!
More welding on the rear crossmember
Untitled by Connor Rhoades, on Flickr
Drill some 7/8" Holes, slide some sleeves in
Weld the sleeves
Grind smooth
Tac it all up
Driveshaft at full bind. Might have to notch when the new driveshaft gets made.
First shipment of ExtremeLED's
Got the bump stops inUntitled by Connor Rhoades, on Flickr
That crossmember turned out nice. Seeing that "after grinding" picture for the sleeves was satisfying.
All the new goodies are nice, now let's see them mounted up!
[MENTION=75445]4Running Daily[/MENTION]
How involved was removing the ABS stuff.
Also, are you guys running an adjustable proportioning valve? I highly suggest one so you can equal out the power to the brakes.
Progress is looking great!
What you see is what I did. Just removed it at the loss of a speedometer. We'll be running a manual propositioning valve at the master. Pretty easy.
Been working on the truck like crazy with Connor in Phoenix so here are a few photos!
Cpn2mss
