SSS Hybrid Bumper Finally Installed!
SD G-Mote
After almost a year of being afraid to install the SSS Hybrid bumper, I finally got the guts to dive in and get it done. I was really afraid of cutting or messing up the front valence. But after reading a lot of posts on this forum and talking it over with the guys at SSS, I decided to do it.
This ended up being a very cool and enjoyable project. Hats off to the guys at SSS for the incredible workmanship and attention to detail. The quality control was incredible. I did not have a single issue with any of the bolts not lining up or the bumper not fitting/ installing correctly. In the end, the bumper looks incredible!
This is not a step by step, but just a few photos of my install. I did deviate from the install instructions and installed the bumper first, then reinstalled the valence. Very glad i did it this way. Way easier to deal with! Send me a note if you have any questions....
Where I started (note the lower bumper was wrapped in black vinyl):
Truck with the valence and cross member removed Note, I did not have a torque wrench but thought my 1/2" drive wrench would have enough torque to remove the bolts. Ended up investing in a torque wrench to get the bolts off:
Bumper with the lower valence cut off. I had read about the dremel tool melting the plastic during cutting. I made sure I had cutting discs, not grinning discs. Didn't matter, it still melted as it cut. What I really did not realize though, the dremel also throws small pieces of hot plastic in your face. Good thing I had glasses on. In the end, the cutting was pretty easy. The Trail Edition lower valence helped keep the cut straight. Lots of residual plastic on the bumper that I remove with my work gloves and smoothed out.
Rubber liner on the bumper to hide any imperfections in my cutting process:
After I got everything off and was ready to install the bumper, I decided to deviate from the recommended reassembly instructions. To make sure I got proper torque on the various bolts, I chose to install the bumper first. I figure that installing a 60 pound bumper, then dealing with a 15 pound valence might be a little easier. It worked out perfect. I also wanted to see if I do it this way, if I can remove the valence and install the winch in a few weeks when I get it. So far, I think I can. Even if I have to disconnect the bumper, it is much easier to hang the bumper first then the valence. IMHO...
Bumper hanging but not bolted yet (this gave me a chance to make sure everything lined up correctly):
Bumper bolted on with proper torque on the bolts:
Finished product :clap2: :
I will be installing a winch in the next few weeks to a month. I wanted to get the bumper on first, make sure I could do it, then install the winch with the bumper. Over all, I am incredibly happy with how it turned out. Again, hats off to the guys at SSS for incredible workmanship!
Very nice! I've wanted one for a while as I don't want to lose that front end look! How does the front end handle? Diving at all?
So far, I have not noticed any change what so ever in the driving or braking. The bumper looks fantastic. Really glad I did this mod.
Just the 65 lb bumper shouldn't affect handling. It's when you decide to add 75 - 90 lbs of winch that you may want some more spring.
Just the 65 lb bumper should't affect handling. It's when you decide to add 75 - 90 lbs of winch that you may want some more spring.
I have the boss tech coiler and springs in the front. I wonder if I will need to beef that up any when I add the winch.
I can only tell you I lost 3/4" to sag on the factory front springs when I did mine (total weight ~140-150 lbs). I have replaced the fronts with OME 885's (2") to make up for the weight. I don't know enough about the Boss suspension to say anything else. But if the Boss setup didn't have some additional weight allowance in it all dialing more in will do is probably give you less up travel. It is probably worth studying on.
I believe the Boss coilovers are sold with a 650lb spring unless you specify you want something else.
Adding 100-120lbs on top of the two 650lb springs won't upset them too much. Especially with a quality Eibach spring which I am fairly certain Toytec is still using. The front shouldn't drop even close to an inch.
Thanks. The last thing I want is to add the winch and then have to redo the from coils. Definitely don't want the rack to come back. Thank you for the info!
If for some reason it does lower the front more than you want, the 650lb coil is still a good spring rate for you. Just add a little more preload and be done with it.
