Are you cutting out the bracket the spare attaches to?
Looking good. May do something similar later. With my backlog of projects I am wimping out and using a Sidekick tank.
I've made several tanks now for various projects....nice thing about making one is it will fit exactly where you want it and you can set it up to run the factory pump/wiring so you don't have to worry about trying to get your fuel gauge to work, proper PSI for the pump to match fuel system requirements, etc.
I am of the strong opinion that you should make a few of these and sell them.
I can't stand the 3rd gen fuel range. It's my biggest gripe about the platform.
Take lots of pics of process this looks dope I want to do something like this down the road, is this gonna be more out of the way then the f150 tanks people do?
Hey there Sean,
Nice work on this fuel cell so far. I am curious to know what you fuel system pickup is going to look like when things are all said and done.
Reason for that is I was curious if you've heard of the HydraMat? If not, maybe check it out. A lot of trophy truck guys and off road racers use them because it does a great job of keeping fuel heading the right direction at extreme levels of angle when off roading or doing heavy accelerating/braking or lateral movement.
Here's a quick link for a better idea of it: https://www.holley.com/products/fuel_systems/hydramat/
Hey there Sean,
You know...the more I think about it....the more I like the idea. It appears Summit Racing has them for $126. https://www.summitracing.com/parts/...se1-_-holley&gclid=CPHR4f7mv9ACFZBbfgodYpkMsQ I'd have to get an adapter to the in tank Toyota pump though. Thanks again for posting. I may go this route....more likely, since I'm poor, I'll go with my design first (it's worked on 3 other tanks)...but if it becomes an issue, this seems a viable solution. I was planning a 4x7" "box" around the factory pickup.....but now, I'll just make it a 4x8" so I can fit one of these hydramats later if needed.....again, THANK YOU for posting! Much appreciated.
Are you going to put any baffles in? I would think they are needed.
