starters - 1.4 vs. 1.8 kw
roscoe67
Member
I have a 1997 4WD 3.4 SR5 manual.
The starter motor just gave up the ghost, after 270K miles. The local Toyota dealer has a starter, but it is the 1.8kw version, which was apparently for colder-climate vehicles. Is there any disadvantage to this? The parts guy at Toyota said it would fit, but I thought I would check - it was hard enough getting the 1.4kw version out through the frame, brake lines, etc., and I hate to fight something into place that won't work, especially as I assume it is a bit bigger.
Anyone have experience here?
This may help.. They both really should fit I have taken both out as i have factory manuals and autos in v6 only. I dont have any 4 cylinders. :-)
If you ever plan on removing your starter, read this first.
I put a 1.8k in late summer when the old parts house one started needing tapping. I can't tell a difference honestly.
I pulled both types through the inner fender. Loosening the brake line bracket makes it easier. Pulling the sway bar off let's it come through the bottom..:)
I have pictures in my repair thread on removing it through the inner fender and the exact position it needs to be in.
Oh, I'm jealous you have a manual. It makes that job sooooo much easier as you can remove the starter completely from the vehicle very easily.
You are in Nevada so go with the 1.8KW version.
No reason to not do the 1.8k really.
Unless there's some differences between the model years, I don't understand all the Installer issues. I removed the 4XI skid plate, and that was it. It is a tight space, and it's a challenge to line up due to the way it's designed without an alignment boss. But in my situation, removal of sway bar or brake line was completely unnecessary.
I do use drive on ramps to lift rigs to work under them.
If I recall right, I think I used a pry bar to hold the starter to get the first bolt started.
My perception is skewed though. Go replace a starter in some semis with a Detroit DDEC 2 or some of that old farm equipment. Way way way less space to work with.
chasebradshaw
