Starting issue
stevestoy
Hey Yall,
I have a little problem with my 2003 V8 4wd lmtd. When I start it I sporadically get no sound a pause and then it starts. I replaced the battery a few weeks ago and thought that did the trick, but it did it again a few days later. I then took it to my mechanic who thought it was the starter but was not sure enough for me spend $640.00 to replace it without being sure of the diagnosis. Now I'm waiting to see if it completely stops when I need it most.
Any help or insite would be appreciated.
Love my Toy,
Steve
You might be due for a starter. If the battery is good, all the cables tight and clean, you might have a failing starter solenoid. The solenoid is attached to the starter and is part of getting a new starter.
I looked at www.Partznet.com, the starter is expensive. That starter is fairly labor intensive to replace. The intake has to come off, you have to buy coolant and some misc gaskets. I am sure any shop that specializes in Toyotas could do it for a little less but it's a big job.
Thanks Chris. I trust my mechanic, it just seemed a little high especially without knowing for sure it was the starter.
Steve
Steve
That sounds like one of the classic symptoms with starter contacts (I believe all 3 rd gen 4Runner had that after 100K). It was $5.00 parts and 3 hours labor DYI.
So if you going to your mechanic I would ask him to check starter contacts first… at least you will not have to pay for new starter just a labor.
044runner4
