Static shock?
Bobby
So I've had my 4Runner for a little over a week and I get static shock every time I get out and touch the door to clos it. Anyone else get this?
Certain clothes I wear will cause me to get shocked as I get out. The way to avoid this is to grab onto the metal part of the door as you are stepping out. The energy will discharge and you won't get shocked.
Funny you should post this. I get shocked almost ALL the time with my new 4Runner. My last car had leather, this one has cloth, maybe the rubbing while driving or getting in/out is causing the static buildup. I got a significant jolt the other day, stopped me in my tracks!
This will happen more in cold weather. Less humidity in the air. Like was posted before - just hold something metal while exiting the vehicle and you wont have the problem. And remember to gound yourself before pumping gas.
Glad it's not just me. I guess I need to remember to ground myself before getting out.
I'm in NJ so they only have full service gas stations. I'm sure I'll get grounded when I get out to pump my own gas when the time comes.
Totaly forgot about the full serve thing. Not only are all the NJ stations full serve they are also the chaeapest anywhere. My self serve is more than your full. LOL
I always get a shock when I get out of my truck. I also have cloth seats. This all started when the weather go cold. I now try to close the door by touching the door handle instead of the black part near the window. Some of those shock really hurt and you can see the flash of light!!
solution!
So I learned this recently in physics class:
(I can't give you all the details/reasoning cuz I didn't pay THAT much attention)
You hold the metal part of your key between your index finger and thumb for 2-3 seconds, and you step out of the car and touch the tip of the key to the metal of the door while still holding the metal base of the key. That will discharge the static. Try it at night--it's sweet. Oh and when the shock is really really big, you see this big spark and you can feel it jolt your arm. But at least it doesn't hurt as bad. Oh and if you don't feel a shock, don't blame me--you weren't going to get shocked anyway. But I swear it works if you're about to get shocked.
I seem to get shocked in any vehicle with cloth seats these days (really dry and cold out), but never in leather. Must be a combination of clothes/seat fabric.
One of my cars (I don't remember which one) had a small pad built into the inside of the door pull. Whenever you touched this pad to open or close the door, it discharged any static electricity to avoid causing static shocks when exiting.
It would probably be easy to do something similar to the 4Runner.
Northof49 said:
Hold a metal part of the door as you're stepping out and there will be no shock.
The problem is that you have to remember to do that every time.
If we had a grounding pad on the door pull, we would never get a shock regardless..... without even thinking about it.
This is correct.
Your butt sliding across the cloth seats creates the charge. It's much more pronounced when the humidity is low, which it is when it's cold.
I'm not sure but years ago you would see a half inch wide strip of rubber hanging from the bumper (or metal part of the car) to the ground (dragging). I was told that this strip would eliminate any static discharge. Might be worth a shot!
Koz
Koz
wouldn't your tires be considered the same thing then??
I'll have to investigate this as I have no solid proof but...
When I was a kid in the 60's and 70's in Oz, our cars had a rubber strap from the bumper to the road that you could buy from any gas station. When we went on holidays to snow ski, dad always said the strap was there to prevent static shock and reduce car sickness. Seemed to work from what I could remember. Families in other cars following us usually had kids who would throw-up at some stage of the 18hr trip and I remember not wanting to be a passenger in their cars -
a) because of the sick smell!
b) because I'd get a shock everytime I got out.
Just my 2cents
Cheers
Mark
slowginjoe,
To answer your question. Static-discharge strips are rubber strips with wires embedded (just found this out) in them that hang off the bottom of the car and discharge your static electricity into the ground. Their only problem is that they wear out, so they need to be replaced.
Also if you touch the glass or a metal part of the door when you are getting off the seat the static should discharge without shock.
Koz
This post reminds me of something that happened last winter...
Our dog has a bad habit up jumping up on my legs to greet me when I get home, which is especially annoying when she is muddy. Like you, I usually get a good size static pop when getting out, and one day she jumped up on me before I had a chance to touch my door to discharge... She didn't know what hit her :D
Needless to say she behaves a little better now when I come home.
johnnya
