Steering Wheel doesn't self Center
achha64
Hi,
My 3rd 3.4L 4WD doesn't self center anymore it steering wheel after a turn or corner, in low or hight speed. I need to bring it back on my own.
My have the limited stock tyre: 265/70/16, all was good before my 500 miles trip last week. What I can is that the tyre wear on the front end.
This can be alignment? if it is, why steering wheel start to not center now and not before?
Thank you
Self centering is (generally) an artifact of a lack of caster. An alignment check would definitely be a good place to start.
Exact same issue I had. Ended up being bad inner tie rod ends. Lift front off ground and shake tires to see if there is any play.
my ear wheel was stuck in the sand, so I use the 4WD once during the trip, and yes there's some surprise hole on the road that was enough violent when I was around 60 miles. Okay I will bring for some alignment first and will see...
As we talk about this: If I use a 275/70/16 instead of my 265/70/16 is this will make my steering wheels hard or not self center even if I made alignment?
Southshore
