Stereo power wires
Sants
Hooking up satellite radio and need to find
1) battery constant
2) accessory
3) ground
Can anyone help with what color wires from the factory harness I should be looking for?
Or link me to the page.
12volts white/blue and red + ignition harness
Starter green/black + ignition harness
Ignition black/red + ignition harness
Power Lock blue - driver kick, 18 pin plug
Notes: Meter the wire while turning the key in the driver door key cylinder.
Power Unlock green (double pulse) - driver kick, 18 pin plug
Lock Motor blue/red to black/white 5wi driver kick, 13 pin plug
Unlock Motor blue/black to black/red 5wi driver kick, 13 pin plug
Disarm Defeat blue/black 5wi driver kick, harness to rear
Parking Lights+ green + left of fuses, 16 pin plug
Parking Lights- green - pin 8, top plug at BECU
Notes: The Body ECU is part of the fuse box under the driver side dash. The three plugs on the right side edge of the fuse box are for the Body ECU.
Hazards white - hazard switch
Turn Signal(L) blue/black + left of fuses, 16 pin plug
Turn Signal(R) blue/yellow + left of fuses, 16 pin plug
Door Trigger purple/yellow - pin 12, top plug at BECU
Notes: Can also use individual door trigger wires in the middle plug at the BECU. The driver door trigger is red/black in pin 23, the passenger door is red/yellow in pin 24, the left rear door is pink/black in pin 11, and the right rear door is pink/blue in pin 12. Use all four wires and diode isolate each.
Dome Supervision white - plug to right of fuses, pin 8
Trunk/Hatch Pin green/yellow - back door ECU in hatch
Hood Pin pink/green - driver kick, blue 18 pin plug
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black/white ac pin 5, conn. E8 at ECM
Notes: The ECM (Engine Control Module) is behind the glove box. Connector E8 is the bottom plug.
Horn Trigger green/red - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Required:
Yes Type:
Transponder
Part #: 556U or 555U
Notes: N/A
I am trying to tap in right from the stereo harness. Looking for
Constant
Acc
Ground
Wire colors on that harness. I'm stumped
This is harness
a5b2a8a0.jpg~original
Pick up a cheap multi meter.....?
Or try this:
This is for the 6 speaker system....
Harness behind the HU:
Gray=ACC Power
Blue/Yellow=Constant Power
Brown=Ground
Pink=Front Left +
Purple=Front Left -
Lt Green=Front Right +
Blue=Front Right -
Black=Rear Left +
Yellow=Rear Feft -
Red=Rear Right +
White=Rear Right -
For the tweeters in the Front doors:
Left:
Red/Blue=Left side + input
Pink=Left side + output (then goes to woofer + side)
Blue=Left side - input
Purple=Left side - output (then goes to woofer - side)
Right:
Red=Right side + input
Lt Green=Right side + output (then goes to woofer + side)
White=Right side - input
Blue=Right side - output (then goes to woofer - side)
But honestly the meter is the way to go to be sure.
1) battery constant
2) accessory
3) ground
Best answer is get one of the Toyota 93+ adapter harnesses. It has everything clearly labeled out, and when I installed my Pioneer deck, the colors even matched, making it brain-dead simple.
BillM777
