Stereo system install pink VSS wire question plz
the pdf version I got from someone. I always use the html version unless I need to search for a specific term.
ight. i'm going to have to keep looking, cause i dont see it yet
unless anybody else knows where the best place to tap into the camera feed is on a non nav t4r
Yeah, it's right there on the first page I posted at the very bottom.
G6-10 "G" for illumination
alright so i found the pin i want, but, now i can't find which wire to connect it to on the pioneer harness. Only a few of the wires are marked! thoughts from anybody? the internet is almost worthless regarding which wire on the pioneer side to hook it up to.
EDIT: It was an orange stripped wire on the Pioneer Side. I couldn't really find to many pin outs on the net, or anywhere on Pioneers site. I just tried it and it worked. It's pretty cool, when you turn your headlights the display dims, which will be nice driving at night...the last few months when i drive at night--i am basically blind. lol. Looking forward to seeing how this things looks at night. :)
Pioneer AVIC X930BT :-)
Alpine M300 4-channel amp
Alpine M500 mono amp
6 Polk Audio DXI650 speakers in the doors & tailgate
2 Infiniti Kappa 3.5" speakers in the dash
Kicker VR12 12" sub and ported box
How do you like the system?
I have a 2012 limited. I like the headunit, but really need to change the speakers as it's lacking. Because I'm keeping the headunit, i'm going to add an AudioControl unit to get the lines setup.
I haven't determined which 4-channel amp to use, how do you like the M300? Is it powerful enough? I'm looking to do the same, components in the dash and 6 something else's in the doors and tailgate. Did you have any problems running multiple speakers out of the same amp channel?
I was also going to add a PDX-M6 with SWR-1243D in the back.
Any other tips on the install or configuration?
Vehicle Speed Sensor
So, I have a Panasonic head unit with this same pink wire. I am looking all over the Driver Kick Panel but cannot see this wire to tap from. On top of that, no search has resulted in any concrete direction. Could you maybe post a pic of this wire to tap the VSS into?
D***!!!! Four minutes!!! You are da MAN! :party:
Seriously, thanks. I'll shoot you a PM as soon as I get it buttoned up, as well as mention it in the build thread. Much appreciated.
Martin Tricycle Motor Works
MMJR_T4R
