I Folded on Plasti Dip & Debadged.
So, I did plasti dip & black out my emblems about two weeks ago.. I liked it, but I felt over time the plasti dip may start to chip, and it would possibly look cleaner with less maintenance over time.. so I took as many badges off as I could.
I removed the SR5 logos on the left and rear, and the 4Runner on the rear hatch.
Here is the method I used:
While heating the emblems up, be very careful on the back panel, I'm not sure if I heated it too much--Or if the factory just stamps the plastic hard... but on the back rear hatch if left a time outline of the 4Runner Logo (see further into post for photos.
Here is the heat gun I used:
http://amzn.to/2rOvu23
Using the fishing line was much easier than I thought, once heated up, they popped right off. The SR5 logos actually just crumpled and fell apart. After the emblems were removed, removing the sticky part was a pain in the ass. I took as much off as I could using my fingers, then I soaked it with label remover. I sprayed wherever there was still glue, let it soak for 5 minutes... after 5 minutes I peeled as much off as I could with my finger... if there was still more, I soaked it more and did it again with my finger.
Here is the Adhesive remover I used:
http://amzn.to/2rxx3lg
It didn't hurt the paint.
Here is what it looked like while it was soaking. I taped down the Toyota Emblem, because I'm sure that adhesive remover would make the plasti dip just wipe away.
After removing the badging, I used clay to fill any sort of scratches or imperfections.
Here is my side panel with out the SR5 logo.
REAR HATCH !! IMPORTANT !!
Well, on the rear hatch, i'm not sure if this is because I heated it too much--or if the factory stamped it hard. But after I removed the emblems there is still a minor outline of the 4Runner Logo.. Also there are 4 small indents, not exactly sure what they are for, but they are under those letters. I'll most likely be sending this piece off to a body shop have those indents filled, and the 4runner outline completely smoothed out.
During the process, it did create a few minor scratches, so my buddy which also has a black car suggested I get a wax that is specifically for black paint..
There for, back to amazon I went, and these two black wax kits are on the way.. I went to look for them at local auto part store, but they only had the spray was for $4 more.
Black Wax Kit:
http://amzn.to/2quQvef
Black Spray Wax:
http://amzn.to/2quJp9P
