gamefreakgc
Elite Member
The next question is whether or not the tensioner was replaced with the TB/H20 pump. If there isn't enough tension on the belt to drive the pump fast enough then that could be a problem. I saw such on a Honda Civic not too long ago. The tensioner was maxed out, didn't keep enough tension on the pump and ultimately a bad head gasket occurred though the OEM pump itself and the OEM belt were fine.
No bubbles in the coolant until it becomes hot correct?
Yeah, I think Little Caesar and I are on the same page here, it definitely sounds like the water pump is not functioning. Take off the timing belt cover and check things out, or try the idling when cold trick I posted back to see if you get any fluid flowing or not.
If you get some, but not much fluid visibly flowing at the top of the radiator (granted it'll never be a raging torrent but it should be noticeable), it might be the belt like suggested above. If no flow at all, your water pump is toast.
Also, this has nothing to do with your fuel delivery or filter. You can change it if you want but that won't make anything overheat.
