Stock Panasonic Battery Life
I had an OEM Panasonic battery in my previous Honda that lasted for 16 years before it died. I'm hoping my current OEM Panasonic in the T4R will be similar.
How long have most of you guys been going on the stock battery?
My truck is about 3.5 years old. Just dropped off for an oil change and 35K service at the dealer. They of course sent me a list of items that need replacing. Rear brakes, brake flush, cabin filter, and stated the battery failed and needs replacing.
Seems like a lot of you guys are going 7 years on a stock battery.
I'm in Texas so the battery is subjected to quite a bit of hot weather but the last year I've been working from home since Covid so the 4Runner has only been seeing a couple of drives a week. I've tried to make sure I've driven long enough each week to keep her charged up.
Just curious, I never really trust the dealerships. I have a pack of cabin filters, why would anyone pay $50 for one at the dealer? Can do the brakes myself and will of course buy a battery elsewhere if needed.
Mine lasted less than 4 years. Granted though, this is ND and the winters are brutal. And the truck was a dealer vehicle so came with higher miles. I have a better cold crank battery from Costco which should go 5+ years. I wanted an AGM but they were out, with no restock any time soon.
As to the question in the original post: I still have the OEM battery in my ‘18 SR5, just turned over 40,000 miles. In my neck of the woods in north-central Nevada, summer highs are in the 100-105 range, wintertime lows can and do drop into the teens and 20s below zero.
My experience: The OEM battery in my 2002 Tacoma TRD died in 2009 (I think it was a Panasonic also). I’ve had OEM batteries in GM and Ford new vehicles die in six months. When Sears came out with the Die Hard in the early 1980s, I installed one in my 1970 Ford F-250 4x4 truck and it lasted 15 years.
As stated before, the majority of batteries are made by few manufacturers, who make them to the specs required by their sellers to sell within a set price point. Sometimes you get plums, other times you get lemons. People swore by Optimas, until they sold out to one of the major manufacturers (if I remember correctly, Johnson Controls) thus compromised, and then they weren’t as long lasting anymore. When I worked in the auto parts industry, warranty returns went through the roof.
OEM lasted just under 100,000 miles, about 6 years and that's through Canadian winters. My wife's rx battery lasted almost exactly 100,000 miles as well in Canadian winters. based on my experience, toyota/lexus OEM batteries are very high quality. My wife's rx battery would have lasted much longer I'm sure of it, but the vehicle sat completely idle for about 1 month at the end of winter and it was drained completely. my 4runner battery didn't actually die, it just tested low so it was replaced as a precaution. I'm also sure it would have lasted longer
I see many upgrading to the AGM types from odyssey or northstar but the stock alternator isn't going to charge them fully - so you can either trickle charge or simply hope it lasts but you aren't getting the best out of the setup
I agree the Panasonic is a good quality battery.
But if your battery drains from being idle for a month it’s nowhere near rated capacity, assuming the car has normal parasitic draw. It’s a risk depending on how you use your vehicle.
My OEM Panasonic in my 2017 recently had to be replaced. Battery was date stamped 2016.
Where I live is tough on batteries. Summer temps over 120°. My 4runner sits idle Wed-Mon every week.
It is depressing reading this thread and seeing many cases where these batteries last less than 5 years. I’m in the hot humid south and have gotten 10 years out of a Walmart battery. I hope to see the same from my 4Runner.
Most times in other vehicles when I thought I was seeing signs of a battery at the end of its life, there was an underlying issue causing its inability to hold a charge. Recently had an issue where the radio had was draining 1-2 amps steadily when the car was off. (Non-Toyota)
I pulled the radio and amp fuses, it rectified the issue for about 2 weeks, now something else is draining the power, and the behavior is surreal. Whatever is draining the power completely stops / shuts off around 7-8 volts. Because you could charge the battery, leave it for an hour, a day, week, or month, and while it will fail to start, there’s always enough voltage to remotely unlock it, and dimly illuminate the interior lights. This makes me think it’s not a dead short but an electronic module (BCM?) that won’t sleep.
my panasonic is 4 years old, but used for maybe 6 months before putting it away for storage, and getting charged up now and them.
just moved it into my standby generator. fingers crossed it gives me a few years hah.
panasonic battery is pretty good for what it is. I recently replaced it, mainly because it couldn't handle winch duty very well. Still working when i replaced it after 5 years. Would have kept it, if i didn't have a winch.
The Panasonic that shipped with my 08 FJ lasted until 2016.
It was still going strong then but I was installing a winch in preparation for a moab trip so I pulled it and installed an odyssey that is still going strong.
Hoping the unit that ships with my inbound 22 ORP is as good.
I was a bit surprised as well. the rx battery that died after a month idle was about 11 years old. It must have been the cold winter that did it. I got 11 years and 100,000 miles out of the OEM battery, no complaints
Can I make a recommendation to everyone - if you have anything that will generate a 12V supply (not just charging) voltage, I’ve used it to bring batteries back that were so low they’d cause the charging set to fault out.
Leave the 12V supply on it for 30 mins to an hour, then switch it back to charging and it will pick right up and safely finish the charge with all the protection circuitry we normally enjoy with modern sets.
This is the same as “hook it to another battery in parallel” but with less amps LOL
Well, San Diego :)
Mine lasted 3 Phoenix summers and died during the 4th.
Well, San Diego :)
Three years of battery life is about average in hot climates, one reason is that the water evaporates faster than in more moderate climates. Maybe topping off the water level more frequently would help extend the lifetime.
worriedgild
