Stolen catalytic converter
Timmy P
I work in a bad neighborhood in chicago and I recently had my catalytic converter stolen off of my 98 4runner sr5. I also had one stolen of my old 87 4x4. Does anyone know about a guard I can buy so this doesn't happen again? What if I make my own, are there any heat issues I should worry about? I don't want running boards. Thanks.
Yeah I had my cat jacked last night apparently this has been going on for quite a while and doesn't seem to be coming to an end. I guess we're going to weld the new cat on and create a skid plate that will run along the bottom of the exhaust. We have to research the heat issue though. And where it'll bolt up, may have to spot weld this too or at least make the bolts an PIA to get to.
Stealing the cat huh... isnt that considered rape?:p
HAHA
ok anyway
If you dont have to pass emisions couldnt you just leave it off and get a "test" pipe welded in?
not in Cali, granted that looking under a old 4runner isn't top priority for the LAPD, the fact that its easy to do should make you think a little.
.........although I am considering it :p
test pipe arent always good. stock non turbo/SC motor need some backpressure. you will loose power if its not force fed. Also sooner or later you would need to put it back on for smog check.
doesnt it (my 00 v6) have 3 cats? one on each manifold or just below it and one secondary cat?
Im kinda new to the toyotas but every mustang i have ever owned that was the first thing to go.
I asked the dealer about this issue and i thought he told me you would probably use more gas and that the engine would not run that great. I would be interested to hear if anyone has tried and what happened. I know there are 2 O2 sensors before and after the cat.
Preventing Cat theft
So IS there a skid plate that can be mounted under the truck to at least deter these crackheads? They stole mine off my 98 while I was at my office.
Has anyone used the catclamp? I can't see how that would work any better... if they are just chopping the pipes off with a sawzall in 2-3 minutes... why would some 1/4 inch cable stop them... wouldn't they just cut them too?
I'd prefer a skid plate option but can't seem to locate any and doubt I can convince my insurance company to pay for a custom made item.
Any preventative measures?
Ok then... some cable cutters then...
Do you use one? Can it be cut/removed easily?
I want to know what users are saying not what the manufacturer is claiming.
I'm trying to find something to prevent it and wondering what people are suggesting and what works.
I think the thing with the cat clamp is that it isn't inpenetrable but would make it much more difficult thus not worth the theif's time. Hoepfully they would simply move onto another vehicle without one.
Re: Preventing Cat theft
No personal experience, but I am guessing only 0.1% of the population has the cables so if you had them they could easily find another victim. Sort of like finding an unsecured wireless network. Why bother with a secured one, when there are a million unsecured ones around.
Then again they might just spend more time tearing your car apart getting through the cables.
Please DO post pics and a follow up about the install! I'm in N. Cali also and bought a new, unused Cat Clamp off Craiglist a while ago and haven't found the time to install it yet!
wayblom
