storage compartment mod
CSL
Using a 3rd gen as a camping vehicle for a family of five and an 80 lb dog is always a challenge. Here is my newest way to cram a little more stuff inside of it.
I removed the black insert inside the storage compartment in the rear cargo area, and what an difference it made! This is a permanent modification as the only way to remove the box is to break the tabs (they are kind of melted together). However, the door still works and when closed you can't tell any difference.
When popping the panels loose, be careful and patient, so you don't break any plastic. Remove the screw at the top of the side panel (near the rear door)
screw.jpg~original
Remove the brackets for the interior cover and remove the kickplate at the base of the door opening. Pop out the 12 volt outlet recessed peice from the top. Then pop out the interior paneling just enough to get a screw driver between the black box and the panel. Break the box loose and then pop the panel back in.
removepanel.jpg~original
I moved the hole for the condensate tube to the bottom, as in the stock position is slightly cuts across the newly created space beneath the base of the removed black box. You can see the old hole on the side, I will get a rubber stopper for it soon.
condensaterelocation.jpg~original
I used some metallic tape that I had (for ductwork) to tape the condensate line into the bottom corner of the area
condensatetaped.jpg~original
Here is just an example of what I easily fit in, with room to spare: 6 foot thermarest inflatable matteress, tire lug nut wrench, 2 quarts of oil, can of spray paint (just as a size reference for you all to see the space), big first aid kit, small axe, rolled up package of diapers and wipes (the blue thing in the photo)
storagenew.jpg~original
Here is all the same stuff inside the old black box. Remember, the stuff inside would never actually have stayed in place in the box when it was up on it's side inside the truck.
storageold.jpg~original
There you go. Easy and free. I am not sure yet what I will put in it (this stuff was just for the photo), but I will post up with a list when it's packed full!!
Very cool:bigok:
Did you wrap the axe & lugwrench with a rag or something? I'd be a little worried about them putting outward protruding dents in the metal.
Great idea!
:cheers:
crafty very crafty...
hey I am online here again! Could not get in here for almost a month. Lost in the upgrade I guess.
cool mod. For those of you looking for a spot to put an amp, this storage box works great for that too which is what i did
I am not sure yet what I will put inside it yet, but that's a good point to consider. Chances are good that the lug wrench will end up in there since I don't have a good place for it yet. I am thinking about glueing some 1/2 inch textile insulation to the metal to protect it and to insulate.
If I was good with metal or body work. I would put an access hatch from outside the vehicle into that area. That way I wouldn't have to move my cooler out of the way to get inside it. Now THAT would be really cool!
I'll have to test out this spot on a few trips and see if I come up with any other ideas for it. Like a shelf inside or straps or something.
Using a 3rd gen as a camping vehicle for a family of five and an 80 lb dog is always a challenge. Here is my newest way to cram a little more stuff inside of it....
Bump for an awesome idea. Was able to fit a good chunk of my recovery in there, which was otherwise taking up space in a duffel bag!
Snuggly stowing my ARB Snatch strap, 65' winch extension, tree saver, jumper cables, and 5000lb ratchet tie-down.
lindenwood-albums-lindenwood-picture45329-modified-cargo-compartment-fits-my-arb-snatch-strap-65-winch-extension-tree-saver-jumper-cables-5000lb-ratchet-tie-down.jpg
Does this put your stuff right up against the outer body panels? I like the idea, but I don't like the idea of stuff rubbing up against the body panels from the inside. I'd be afraid I put something too heavy in there and it starts denting it from the inside...
I did this mod last year. You can about double the amount of storage space. I lined the entire cavity with carpeting to prevent things from banging around.
I like that idea! I need more storage space in mine and this is looking like a good option.
Yes, it opens the compartment up directly to the body panel, and indeed that is a very valid concern!
Lining it with a thin carpet is a great idea, though! A combination of sloth and apathy (admittedly borne out of a relatively busy and stressful job) will likely prevent me from getting to that point, though :P . Hopefully, the relatively soft things I have in there will keep rattling and denting to a minimum! I thought about trying ti stuff my D-ring shackles in there, but I'll jist keep them in the cabin until I build my bumpers and then just leave the shackles on there.
Awesome free mod never heard about,going to do this as soon as possible,my compartment is so full every time I open it stuff falls out got me thinking has anybody ever attempted to put a storage compartment on the driver side?
Sent from my iPhone using Tapatalk Pro
Is the back passenger panel compatible between the earlier years with the small door, and the later years with the larger door? I could look in the junkyards.
Also what about the driver side which has no compartment? I guess the gas tank fill gets in the way.
Yes. I have all panels from a 99 in my 97. The 99 panels also have a 12v dc outlet built in just inside the rear door/hatch so if you get 12v's back there somehow you can have a plugin... I havent had a chance to hook mine up yet but i would first start with the brake light wire as it is always hot...
One thing i do remember is having to cut a lil metal on the pass side so the newer panel/cubby will fit. If you go ahead and take off the cubby box completely as the OP mod suggest i dont think you will have to do any trim work
Also, there is a lil space on the driver side but there is a breather vent back there you'd have to do away with and also figure out how to make a decent looking door. If i recall, the most difficult part was having to replace every piece back there so the colors would match from side to side but you may get lucky and find the pass side panel in the color you need. Good luck
You should remove part of your last quote, its the whole thread, thanks!
This. Highly recommend carpet otherwise it gets noisy.
Even us with the tiny storage compartment lid can enjoy this, it's still the same sized cavity. But you really should glue some carpet on it first.
I thought about it when I had it all apart for sound deadening, but the air vent and gas cap take up most of the room. Plus I have no idea how to cut into the paneling to make an opening that wouldn't look horrible.
