tobenisstinky
Junior Member
I just had something similar happen to me yesterday and after spending the night searching various forums, I found lots of mention of stripped teeth and hundreds if not thousands to fix. My sunroof would move a little back and forth, but would not close.
First, I found that the pins on the ends of the air deflector arms had come out but could easily be replaced by pushing the air deflector down which pulls the arms slightly forward. My sunroof would then close half way. Hmmm...progress...so in my case it did not seem to be stripped teeth. I remembered reading on another post that holding down the "tilt" button for 15 seconds would release the motor and allow one to close the sunroof manually. This did not work for me. Maybe 3rd gen?
I looked in my owners manual to see if it said anything about a reset procedure, and found this tidbit of information: To normalize the moon roof - push and hold the switch on the "Tilt Up" side until the moon roof tilts all the way up and then tilts down a little automatically. BTW, its under moon roof in the index, not sunroof.
This apparently can occur if the battery is disconnected; run down or the jam protection has been activated even once, and the vehicle has been turned off since.
The first time I tried this it didn't work, so I disconnected my battery for about 10 minutes, reconnected, and tried again. It worked! my sunroof now works perfectly again. Hope this helps someone else.
