So my wire decided to break again...looks like I didnt get all the corrosion areas cleaned. So ima rip it all out and replace it. What kind of wire should I be using? Any tips? Ideas? I'm fed up
Since you're doing the grounds, you might as well do the two big ones coming off the negative terminal on the battery. One to the passenger fender and the other one to the right side of the engine block. Also, check the ground wire coming from the firewall to the head.
