First of... I did the required search and did not see an answer to my question.
Simply put, my son wants to add a JL Audio sub box with a 1200watt amp to the back of a JBL optioned 04 4Runner.
Powering the amp is not an issue, but with a NAV head unit, what wire is the sub trigger wire and is it accessible near the factory amp? If not... what is the trigger wire of choice?
Lastly... (prior experience on Ford sub units) in order to amplify the sub signal, can the harness feeding the factory sub unit be disconnected and wired directly into the amp? Any filters or splitters needed?
Thank you in advance
