Sudden drop of MPG
Its the fuel. The ethanol has less power in it so when you replace gasoline with ethanol, you get less work out of it and therefore worse MPG.
Also, it is counterintuitive but higher octane gets worse mileage. If you can run 87 without pinging, run it.
I actually have consistently noticed increase in mileage with all my v6 vehicles?
the mileage i quoted above is for intra city driving, max speed 40miles per hr...less than 25miles commute per day...actually abt 10miles to n fro office.
last time i did a 220mile trip..i filled my tank and the needle was at the halfway mark at 190miles........though my trip meter normal settles around 320miles when i fill ip my tank at the gas station.hv changed my airfilter..next stop is changing out the 6 plugs.....considering if its worth doing the HCF mod delete, yet to see a solid confirmation of mpg gains from forum memebers.
I did the mod and got a roughly .5 mpg increase with my V8...... Not much but every little bit helps.....
am here in LA...and always gas Chevron...every one say its the best gas out here...wondering what u think...
Everything has ethanol around me. I think any gas without is better than the best with ethanol. Chevron is good gas. Each state is different with the ethanol addition. I'm in the Buffalo area and since it's cold during half the year they just keep the ethanol in it. I try to fill up at the stations on this list near me as much as possible.
Ethanol definitely hurts the MPG - Luckily i live near an area that there are marinas and boating which CAN NOT use ethanol so non is available - Check out link below for ethanol free gas stations near you.
Ethanol-free gas stations in the U.S. and Canada
Unfortunately in high demand area many of us are paying $5+/gal for ethanol free. I just filled the boat up today when we got back and it ran me $426 For the partial fillip. I will keep using regular shell 93 (with ethanol) in the 4Runner for $3.73/gal.
What type of gas don't have ethanol
There may not be ethanol free in CA but here it's normally 10% ethanol but with boating and marine needs that cant have ethanol at all there are a few stations near marina's that don't have ethanol.
I'm in San Diego. Just purchased 05 V8 2WD and getting 16.5mpg on the internal computer. Gentle driving, 50% freeway/50% town roads. Car has 46K mi. Runing premium Gas.
My MPG just jumped up to 18 (was 16.5) using the on board computer. I'm driving the exact same roads and speed. Summer gas?
changed my spark plugs and did a 250mile trip, my onboard computer showed 19.8avg mpg instead of the usual 13/14 it normally shows...bought the trcuk used at 113k , now at 120kmiles..so no idea when last the plugs were changed.
just observed my front passenger wheel hotter than the others.....seems i hv the infamous siezed caliper problem!!!....arrgh....thinking of buying new clipers and rotors and swapping out both front caliper/rotors...was having the steering shakes when braking at high speeds..so it appears my rotors are warped too :)
Both front O2 sensors replaced and MAF cleaned but after 2 tanks, I'm still looking at about 12mpg!!! Front brakes are fine, pistons not seized. Any ideas on what to try next?
HCF removal helped mine quite a bit. it was so dirty i don't know how any air got to the engine. Also changed my plugs to NGK iridium and helped me by 3-4 MPG. Just a though
I don't think it's the battery. Battery is there to provide power to the car when engine is off for the lights and other electronic. I would say that your alternator is not providing enough power when engine is running, thus not giving enough spark for combustion.
I replaced my battery a year ago and I did not notice any mileage improvement. A few weeks ago, my dashboard battery light came up even when engine is running. To make it short, I ended up replacing my alternator and that fixed the battery light problem. I measured the voltage at idle with all the lights turned on, high beam, AC on high, and the reading was 13.5V+-. if all accessories are turned off, it reads about 13.85V at idle. I also notice my mpg has improved. So anyone with issues with mpg, you might want to check your alternator output. I hope this helps.
This is going to sound odd, I recently noticed my MPG's dropping. Figured it was because I was stepping on it, then I realized I really wasn't doin alot of leadfoot driving.
Then I started having issues with my battery with the cold & all here in Colorado...battery would turn the motor but not with it sounding like it didn't want to. So then I took my battery in to get tested. Red Top Optima- and it was no good! So because of the 3 year warranty I was able to get a replacement. After I installed. the MPG's came back! With an attitude! So I'm not sure if this has any connection to the other but...that's my $0.02.
Hope you find a solution. Let us know.
Ian
Bringing this back from the dead. Here it is 18 months and 7000 miles later, my mpgs never changed. I'm still getting around 13.5mpg. I've started thinking since mine is a full time awd, that my center diff is acting up. I've checked all brakes, all spin freely. I've bought gas in 3 different states (Nevada, Cali, and Oregon). My on board computer says I'm getting 19.9mpg, but when hand calculated it's 13.3-13.8mpg. I did realize that I lost the mpg AFTER the gas peddle recall. When they did that, they also did a reflash. My shift points changed also. Anyone have any more ideas?
charlesz
