Suggested Maintenance
Lawman
We have a 2017 4 Runner with 100,000 miles..I want to put at least another 100,000 on it...In order of importance other than oil changes and air filters what preventive maintenance should I do or not do particularly regarding transmission? Thanks!
Sparkplug, pcv valve, diff fluid front and rear, transfer case fluid, transmission fluid drain and fill. Replace coolant, brake fluid. check the drive belt, grease the drive shaft. Air filters engine and cabin. Check brake pads. I am of the opinion that trans fluid should be replaced on toyota trans even if has over 100k miles others will disagree. Good luck.
erinobr2000
