Suggestion for steering wheel vibration
jhebert9
RF balancing solved my problem. I told him that a lot of 5th gen owners have a problem with vibration. He suggested that if the problem is still there after balancing what he does is to deflate the tire and rotate it slightly on the rim. Those of you with vibration problems try this if you haven't tried it already.
When road force balancing is done correctly the machine tells you if tire needs to be rotated on rim and how much. But like everything in life lazy and easy way take over. I too had vibration problems on my previous truck a 2005 tundra D.C. And the tire shop I use has road force balancer and know how to properly use it. Problem solved!
youngrk
