Sun/Moonroof water drains
Atlanta_man
I've found and cleaned out the front drain holes and tubes using the weed eater line and a hot soapy water flush. No more wet front carpet.
But...
Where are the two back drain holes and how do you get at them from the top of the open sliding roof panel ?
Or should I try to find the other end of the tubes somewhere around the back wheel wells ? Seems these may be hard to get at since off road mud would likely clog them but good if they are exposed.
This should give ya a better idea
Haven't had to (yet), but I'm not sure you can get to them (green tube in the pic below) without ripping out the side interior plastic (C pillar).
Found this for ya:
CIMG5414.jpg~original
credit: LINK
Not sure where the drains are at the sunroof, but if you check by the jack, you should see the drain in that area & can determine exactly where it exits.
Jhunt
