Sunroof Repair
I tried to fix my sunroof a few weeks back. Stuck in the closed position, but still leaked.
I ended up dropping the whole headliner to clean the water stains. While it was dropped I ran weedeater line through all the drains and they were not clogged at all. So there was obviously an issue with the gasket around the glass.
When I saw this, and that it would not open because the teeth on the motor were stripped, I just put it all back up and used some leftover RTV Gasket Maker to seal the whole way around the top.
It now stays bone dry, even with all the crazy rain last week.
FYI, Harbor Freight sells the black Permatex brand RTV for like $3 vs the $7-$9
at auto shops. I would almost suggest getting some of this and 're-gasketing' anything you thing might be leaking at all, just in case. Cleans up easy if you're quick and blends in great.
I had this issue when I first got my truck..
Drain holes were fine, roof itself seemed fine, in the end it was the join in right in the centre of the weather stripping. I didn't really notice dripping just damp marks on the headlining
I ordered a new sun roof from Toyota... it should be really fast job to replace, just pop the plastic trims off at either side on the inside to reveal the bolts...
I removed the entire mechanism before I discovered this...
Yeah, I'm not quite understanding how my headliner is getting so wet. I check the moonroof and although there is water near the drain holes, they seem to be doing their job. I can't see where the water would go from the drain channel to the front of the headliner.
This lead me to believe that it's the windshield gasket (I have rust issues all around the windshield that were previously repaired by the PO, but I think the rust spread more now). So I used a clear silicone caulking around the top part of the windshield and I'll see if that does the trick.
delislerebecca
