Superman3043's Build Thread
My cousin just texted me to ask of I knew anyone wanting to buy his, it's a 2006 Galactic Grey 4wd with a Daystar spacer lift a 32" BFG takeoff from my uncles Rubicon. I think it's the V6 though. Last time I saw it, it was really clean with no problems, but I can let you know on Saturday when I see him. He's in Statesboro, GA and wants 15,500 for it
I certainly appreciate you looking out for me, but 15,500 is a bit out of my price range, sadly.
My TOP is about 12,500. Even then that's assuming I don't get beat up when I sell the Rodeo.
But, I won't be in a place to buy for another couple months anyways, I want to get some more money saved up so I can go in with a decent down payment and limit my losses from having to take out a bigger loan.
Speaker Grill Repair & Recovery/Emergency Kit
I've been really bad about posting here lately. There are a couple of updates, I'm going to add so just bear with with me. I've been out of commission with a broken arm for a few months, so the mods and thread updates just sort of piled up. That coupled with the fact the my friend and T4R.org member is apparently dragging me back into the world of paintball has got me less focused on 4Runners and wheeling as of late... Thanks [MENTION=65653]aha2988[/MENTION].
So this first "mod" was really just birthed out of my anal retentiveness. I damaged my rear passenger side speaker grill when a heavy part I was hauling, tumbled across my floor board while I was pulling out into traffic and accelerating hard. Purely cosmetic, so some would be inclined to let it be.
Inner door panel looked like this:
ordered some of these to repair it with:
Start:
Basically just cut out the old plastic and bolted up the new grill... simple:
Installed:
Allows me to show off that nice JL Audio hardware that was hiding behind that door panel:
I know... Boring!
Also put together a little recovery/emergency kit on the cheap:
Next...
Horn Upgrade
The next mod came from me wanting to upgrade my horn. I've always been intrigued with train horns, but really can't justify the cost and real estate they require for what seemingly little real world use that I'd actually get out of them. I began a search for a more economical replacement solution. Originally I was interested in the Wolo 619 Big Bad Max Black 12V Air Horn Kit. The low price and fact that it was a consolidated unit with it's own built in compressor was intriguing. After reading some mixed reviews (apparently the early models had some diaphram issues), my research led me to the PIAA 85115 Superior Bass Horn. The price was a little higher than the Wolo unit, but what intrigued me about this one was PIAA's quality, and the fact that it was a dual horn set-up like our stock ones, so the hope that it was a direct drop-in replacement. So I ordered them:
My intention was to do a nice little write up and review, maybe with install pictures and videos. I even downloaded a couple of apps that I was going to do some sound level and tone comparisons with.... but like all of my installs, I got rushed and lazy.
Anyway, so here are my thoughts:
Install: Super simple. Yes this is basically a drop in replacement. It took about 15 minutes start to finish. You basically remove the upper radiator shroud by pulling out the push pins and that gives you access to the horn mounts. You remove the entire mount from the upper radiator support (2 bolts, M12 socket I believe) as the new horns come with their own mount brackets. The factory horns have a nice little splash shield at the horn opening which the PIAA's don't. DO NOT attempt to disassemble the PIAA horns in order to use any parts off of the factory horns. It's printed on the parts and instructions, because taking the thing apart will ruin the horn. Bolt the new ones up. Wiring the new ones is a little different as the new horns have two spade terminals (hot & ground) where as the factory horn just has a single connector. Still simple non-the less. The factory connector will actually push right on the positive terminal and the new horns come supplied with a length of wire with a female spade on one end and a ring on the other to find ground with. I grabbed mine from a nut right on the core support between where the horns mount (M10 socket). That's it.
Quality: Time will tell, especially with the horn being more exposed than the OEM's. PIAA has a good reputation in the industry though and these appear to be of great quality from my initial impression.
Performance: So the factory setup comes with a 500 Hz and a 400 Hz horn. This one comes with a 400 Hz and a 330 Hz horn. So truth be told, I don't see why you couldn't achieve the same result by sourcing an OE style horn spec'd for 330 Hz. To expect any gains in db, would be unrealistic as they're essentially the same style horn, driven by the same power source. Basically it just changes the horn to a "bassier" tone. Personally I don't know how I feel about them yet. They don't really seem to knock my socks off or anything. So I'll let you be the judge. While I didn't do everything I wanted to do, I at least did make some video for you folks.
Stock:
PIAA:
Hope that helps somebody. If you have any questions just let me know.
Up next for me will be to install this cheap little PA speaker for my CB:
And to try to use this to mount my hi-lift jack. I'm thinking about bolting it to my speaker box to keep it protected from the elements and theft... We'll see:
Thanks for looking!
Who's gonna win when y'all play eachother?
I'd put money on the guy thats been practicing the last 6 months, and not the guy that just got done nursing a broken arm lol
:reddance: I'm gonna be all like pew pew pew :gun5:
Sounds like a good bet. Not only have I not played in 8 years, but I'm an old geezer too. Maybe you should give me 2 to 1 odds :wink2:
you ought to get the control box for this that makes all the different pre-recorded sounds like animals and sirens etc. Michael has one and it's hilarious in traffic an what not lol
This is one of those things that I'll probably get very little use out of... Good thing it was cheap, lol.
Well that is about what I said when you mentioned you wanted one. Maybe an Army / Navy Surplus store would have a real one?
bahahaha
price of a cheap recovery shovel: $11.00
my reaction to the review an posts of it breaking.. Priceless
oh an another note, sarah called an said you texted me. i left my phone at the house so not sure what the message was..
AndiGarage
