Survey, what brand of engine oil
Larry
There's been a lot of talk about synthetic oil or dyno oil and change intervals, how about signing in with the brand name/type and viscosity of engine oil that you use in your 4Runner, no comments just list it.
Mine? Redline (synthetic, ester based) 5w-30, what's yours?
I will be using Mobil 1 10w30 year round starting when my 4runner gets to the 5K mile oil change interval. Mobil 1 10w30 gets the best used oil analysis results in our Toyota 4.7 V8's on www.bobistheoilguy.com used oil analysis forum. It also has a cold cranking number of 3967 at -25 degrees F. That is as good as many 5w30 dino oils that are recommended for below "0" use. As long as the cold cranking number is below 7000 you won't have any problem with your engine so the Mobil 1 10w30 should be good for any Toyota 4.7 V8 year round in the continental United States. Check the site out and checkout the used oil analysis section, if you do I think you all will start using the Mobil 1 10w30 oil in your 4.7 V8's.
Mobil 1 10W30 Every 5000 miles
Mike
I change all my cars at 4k miles with a Toyota filter and Mobile 1 5w30. My Lexus has 115k miles on it and when I removed the valve cover and oil pan it was spotless. My wife came outside and saw her car taken apart. It was priceless on her face when I told her I was just curious as to how the inside of the engine looked!
I just did my first oil change and used Mobile 1 5W-30 under the recommendation of several mechanics. They said 5K intervals under any driving conditions anything before 5K with synthetic is overkill. I'm no mechanic, so I'm taking their word for it.
ironTrap, what makes GC different than domestic Castrol? Is it more expensive? Does it meet some ACEA speck that domestic Castrol does not. I understand that the API is a one size fits all approach and you have to be careful what you are using. ACEA has customized specs and is very specific, unlike the API.
Go here and learn all you want about GC www.bobistheoilguy.com
I just did my first oil change this weekend. 2200 miles on odo and noticed some metal in the oil. Glad I didn't wait until 5,000 miles. Took me a while cuz some gorilla in Japan had the filter on so tight. I got fed up did the old school trick "screwdriver".
BTW, the filter on the truck was made in Japan, but the filter I bought from www.trdparts4u.com are made in Thailand. Different part number but same size filter.
5w30 Castro GTX
From what I've learned, GC has a much better additive package than domestic Castrol. It's also a little heavier than other 0w30's. The most unique thing about it is that it's green. Go to the site Pitbull mentions, you can find out more than you want to know! That's where I learned about GC.
Royal Purple Racing 21 as soon as I get some more miles on it. Don't know OCI yet, will monitor and tune with UOA's and Lube Control.
