Suspension lift question
Keppers12
Member
Hello-
Looking for some rear spring recommendations. I originally put a 2” Kings suspension lift on my “08 with Dobinson springs that were rated
For 2” lift at 40” pounds.
Apparently my RTT and camp kitchen don’t weigh all that much as the rear end is 2” higher than the front.
Hopefully someone out there knows a good spring that won’t break the bank! With the Kings, icon UCA”s and $350 for the Dobinsons im ready to be done!��
Thanks in advance!
Rear is .5-1" higher than the front from the factory. If you didn't specifically put on a 3" front lift and 2" rear I'd expect the rake to stay.
The other question is about the condition of the components used. Were all 4 springs & shocks brand new?
There will be some settling over the first few hundred miles after install, so your current height may settle out a little if the front was already installed and the rear was just done.
Thank you for the response. Everything was brand new and was recently installed. About 3 weeks ago. I guess I didn’t realize it settled that much.
Jkmazon
