Suspension lift
StormTrooper
I'm considering a Revtek 3" suspension lift for my 05 4runner. it will cost around $730 including install out the door. is this a decent or fair price? any opinions on other brands? i have no experience with this sort of stuff and need someone else's opinion. also i need wheels and tires. this lift should fit up to 285/75/R16... do i need that big of tires for a 3" lift or would i be fine with smaller tires?
Some other member was talking about a Les Schwab special in the very high $600's I think, $730 doesn't doesn't sound crazy. 265/75/16's will work well and look good. With 285's you'll have some UCA (upper control arm rubbing) with the wheel fully cut.
Good luck and post some pics when you're done.
:cheers:
First off, start with the search feature. There're lots of threads on lifts and tires. Stock wheels will most likely work for you too to save some money. A 2/1 or 3/2 spacer lift and 265/70R17 (or 16" equivalent) and spidertrax wheel spacers will get you the most lift for the $. If you really plan to off-road, spend the extra on coilovers or OME suspension. For a mall-raider or mild off-road, spacers are fine.
