Sway bar endlinks and bushings for an '02 T4R
JohnnyMack
I searched T4R.org and got conflicting information...
I need help locating a company and or part #'s to replace my rear swaybar and endlink bushings.
*UPDATE*
A T4R.org member sent me this link and I ordered the front bushings that I needed from: Anti-Sway Kit for Toyota 4Runner from Wheeler's Off-Road
But I called them and they don't sell the rear swaybar and rear endlink bushings for an '02. He said it was a different diameter and he isn't sure who sells them for my application. So, I'm 1/2 way there....
Who sells the rears??? Any help would be appreciated!
Hey man, it's definitely a sketchy area. I use energysuspensionparts.com. I've always had good luck with them. Just got my rear sway bar bushings. part#181116 -19mm. I haven't put them on yet so I'm not entirely sure there actually correct. You can call them and see if they can weed this out for you. Got all my front bushings from them and they were correct. Though, I have a '96 so my sway bar diameter may differ from yours. Hope this gives you a lead -
These are all for aftermarket end links and bushings. Don't know if you want aftermarket or go right to Toyota for the bushings and end links.
I have Mevotech on my 2001 and they seem to be holding up. 2+ years so far.
Mevotech
End links - MK90619
Bushings - MK90551
Beck/Arnley
End Links - 101-4909
Bushings - 101-5916
Moog
End Links - K90619
Bushings - K90551
Mevotech
End links - MK90619
Bushings - MK90551
Beck/Arnley
Bushings - 101-5916
Moog
End Links - K90619
Bushings - K90551
Did you do an advanced search? (Just checking)
See the link in my signature.
Thanks for the help, guys. I read and talked to someone that said the diameter of the rear swaybar on the '02 is different than the previous years of the 3rd gens. Still trying to find the correct info.
Yes, I did do a full advanced search and I do appreciate the walk through you provided in your sig. Thanks y'all! :happy:
*UPDATE*
I bought both the front and rear sets in your link for my 2002, and they worked like a charm. I'm not sure why they're telling you they don't fit. Uness 2wd has different sway bars and/or end links from 4wd.
Please keep this post updated if you find out that the 02 rear sway bar is a different diameter. I also have a 4x4. My swaybar bushings are in good shape, but I will probably replace the end link bushings soon. I noticed one is looking a little rough. Probably a 10 minute job, but I might as well do the whole setup at that time.
All I come up with is that the bar is the same diameter from at least 99 on up. Don't know about the earlier years.
Stabilizer Bar Diameter (front/rear) 1.02 (26mm)/0.75 (19mm) inches.
*UPDATE*
i have an 01. i looked there and they don't have end links and bushings. i need them too and would like the links to have urethane bushings. who has these?
I just bought sway bar end links and bushings. I just went to Camelback Toyota online, very easy to use website.
Just search under suspension and they are right there.
i saw them. do they have urethane bushings? it looks like you have to buy each piece.
