sway bar link bushing question
jayk2k3
A Mechanic told me these sway bar bushing mounts are bad, because there is a Hair of a space between the bushing and sway bar. I tried another set but it was the same, should i use a different brand?
I am not sure what you are actually asking...
The OEM bushing works best with OEM sway bar brackets....
Measure your sway bar as I have noticed some come with different size bars.
Good Luck!
I agree with others. I can show your bad bushing mounts. Those look fairly decent.
Sent from my SM-J337V using Tapatalk
thank you for the input, i will try a oem bushing and also measure that sway bar. A mechanic was trying to tell me that the bushing had collapsed because there was a hair of a gap and it didn't fit flush with the bracket.
