Sway Bar Links
KwonRunner
Member
Dobinsons vs OCD?
Just Rear vs Front and Rear?
Pros vs. Cons?
Dobinsons vs OCD?
I can’t remember for sure, but I’m pretty sure that I have seen a thread or two that I’ve said the second GEN runner sway bar links are longer and work well as an extended sway bar link at a lesser price
I’ve that that too. For the rears.
Thanks for that recommendation. Found some more info on t4r and am leaning towards either
1) the Proforged 113-10144 Link + energy suspension grommets for the rear and take off the front sway bar
or
2) just get the front and rear OCD links
At what point of lift do you guys recommending getting extended links?
I'd say it's not a bad thing to get, even with a mild lift. I have at least 2" in the back, ~3" in the front. I've broken a rear link mount before and want to prevent that. I've also heard of the front links potentially breaking and messing up your CVs. If you're doing mild wheeling, you should be fine without them.
H.Sikina
