Swaybar Parts
ellroy2
I have a 08 V6 SR5 4WD that I am putting a new suspension on. I want to have some other parts replaced while it is being done. What parts should I plan on replacing? I am planning on swaybar bushings and end link bushings, but do the actual end links need to be replaced? I want to get all of these parts ordered, so do you have the part numbers for what I will need?
What type of suspension? You *should* replace the control arm bushings while everythings already out. If you're lifting, and it's not just spacers, I would also recommend upgrading the UCAs. According to most it makes a huge difference in the ride quality both on- and off-road. That is, if you aren't already, and you have the extra coin.
You can get all the part numbers by searching, or going to autozone, rock auto, ect.
You don't necessarily have to replace other parts. Just check your ball joints, and cv axle boots while you are doing the install. Unless you are having a shop do the install. Then ask them.
It's a standard suspension(non XREAS). Putting Moog FJ coils and 5100s on. I am living in Baja, Mexico right now and parts take awhile to get. I want to have everything for my mechanic ready to go for when he does the install. I will probably get new swaybar bushings to help with roll, but I am mostly concerned about replacing parts that should be replaced at 83k miles. I don't know if things like end links wear out, or if you normally just replace them for performance reasons.
delislerebecca
