Switch Blanks in Console
Glad to know it fits fine!
Where'd you put the switches? In the two blanks in the center console? Do they look OEM?
I'm still on a search for the correct trim piece so I can put the switches in the 'stock' location
I moved the one switch over. Come to think of it, mine are slightly different.
Those look good! I'd like to save those blanks for more projects, but if I can't find a part number to order the correct trim piece, I might just move the DAC button over.
How hard was the DAC button to move over?
It's easy to move the switch. Just looks better moved for looks.
Carbon Fiber Universal Heated Seat Heater Kit 5 Position Dial Ships from USA | eBay
This is the kit I bought. In the pic its lit blue, however, mine lights red. They must of changed it. And never updated the pic. I was happy with the change, since the red blends perfect with the stock lighting. You just need to file the stock opening just ever so slight. Took 30 seconds.
Took apart the console on my limited these are the numbers I found on the bottom. Don't know if this will help
58822-35020 appears to be the correct number after some Google Searching!
Thanks man, I've been searching for this part number since Christmas!
i've always wanted heated seats but never could justify them since i live in southern california and we have no idea what snow and cold weather is. but i've recently considered adding it in, just because it would be a fun add-on.
where did you wire everything...add a fuse...tap into other wires? how difficult was it? and does anyone know if they're safe to add to the stock non-leather seats?
